Complete 1960 dated 383 HP engine for rebuild,
£££ offers,
thanks Paul . |
Location: Southern California | If it's 1960 make sure and specify it's an RB 383 1960 not B 383
Just FYI
I just rebuilt my RB 383 much rarer motor :D |
No this is early 383 B block , 350 361 383 400 , the RB 383 was the later engine same as the 440
So this is a B block 383 with engine number on right under distributor ,8 bolt threaded crank flange ,it originally came out of a Facel vega with cast iron torqueflite,
Thanks Paul. |
Location: Blackpool, United Kingdom. | Any takers? Just had a look inside, 8 bolt crank 10 thou over looks good , pistons 30 over but had water in , so will need a bore 40 should clean up good , centre drop sump , heads are 1851809 (59 HP heads with larger inlet valves, HP stamped oil pump ,can put on a crate if you need to courier it.
Paul. |
Location: northern germany | springsweptwing - 2016-01-25 11:36 AM
Hi Mike,
Thanks Paul.
sure the crank flange bolt holes are threaded?
Edited by 1960fury 2016-02-02 3:37 PM
Location: Blackpool, United Kingdom. | 1960fury - 2016-02-02 8:35 PM
Hi Mike,
Thanks Paul.
Not on this engine crank flange has holes for converter studs to go through, sorry was thinking of other crank I have. |
Location: northern germany | i need a 383 but i guess shipping would be the killer and as i need a t-flite and 8.3/4 axle too buying a parts car is probably cheaper. |
Location: Ottawa, ON | Unfortunately i don't have the money. Would be nice to have one engine as spare. And sid, i'm pretty sure shipping is cheaper than from the US...? |
Location: northern germany | Polara61_383 - 2016-02-02 6:31 PM
yes, but i need a transmission and axle too, so a parts car is the way to go. buying and shipping a transmission and axle separately from the US is going to cost more than a complete car and since i have to buy a parts car anyway, it makes no sense to ship an engine from the UK. |
Location: Blackpool, United Kingdom. | Update on engine , had to use the rods and rocker shafts on my 350 , so engine can be split for parts if anyone needs anything ,
Sid and Nikolas if you want to club together and get someone to collect it may be better for you both ? Does not seem to be the interest over here anymore and rather it go to someone who can use it , than it go in the scrap pile i can keep it here for a while for you.
Paul.
Edited by springsweptwing 2016-02-03 6:10 PM
Location: northern germany | you mean you parted a genuine 383 hp to fix a 350 okay, anyway, yes if you have something for sale let me (us) know. but you are not going to throw away a 1960 hp383 block, do you? |
Rods are same part number as my 350 , just was easier to take the full set of rods and use them as 2 of my 350 ones are out of round due to spun bearings , so there are 6 good rods with it and I cannot find my rocker shafts as engine been in bits 4 years ,
I know what you're saying but over here this is just a worthless lump of scrap iron , that's why I would sooner give it away than send to scrap , it's not in way at moment , but cannot keep the stuff forever ,
Paul. |
Location: Ottawa, ON | So it's the block, heads and crank, right? |
Heads
Crank
Camshaft
Oil pump
Sump
Chain cover
Waterpump and housing
Fuel pump
Crank damper
Inlet manifold
Rocker covers
Plug wire brackets ( usually missing )
Hyd followers
Pushrods
Right exhaust manifold
Location: Blackpool, United Kingdom. | Engine gone to good home thanks polara61 383. |
