Location: Southern CA | On the firewall are two oval shaped drain holes to drain the cowl/heater core area. I bought two new oval rubber flaps that are supposed to cover the holes, but I don’t see anyway to attach them. I’m probably missing the attachment parts. Can someone please post a photo of the parts and/or advise where to get them? Thanks, |
| ah grasshopper, you have stumbled upon a question for the wise masters...
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=66044&... |
Location: Southern CA | Thanks for the link. The rubber flaps I purchased have the nubs on them that would pop into the two holes at the top of the oval drain holes, except my car doesn’t have two holes at the top of the oval drain. I think I remember seeing a photo of oval shaped stamped metal “clips” that snap on and provide the two mounting holes. Those clips are likely unobtainable, but if I could find a photo I could put an ad in the Wanted section and possibly find a pair. Otherwise I might try using weatherstrip adhesive to glue in the top and sides of the rubber, leaving the bottom open for drainage. |
Location: So. Cal | The drains with no holes used a rubbery tube that inserted into the hole and clipped on. It wasn't just a flap. Gary Goers is your only hope for those, but I don't know what his business status is now. You might be able to find some good ones from the Eastern half of the country. Here in S. Cal, the originals fall apart if you attempt to touch them. |
Location: Southern CA | Thanks Nathan, Gary sells a slightly larger version of flap for cars like mine with instructions to drill two holes for attachment. I’ll be cutting a pair of flaps out of neoprene and attaching them with weatherstrip adhesive applied to the top and sides as I have no room to dril. Problem solved. |
| the non hole version(57).
The water would sit there until it dries and you can often see rust holes there. It rains... water sits... anything wet goes..it sits there, bad design.
The flaps are there so fumes don't reenter the interior of the car. so you want it to drain but not have open holes to the interior.
I will just make sure the seam seal completely fills the bottom and water must flow out the flap and not sit.
Location: Southern CA | Hey Mike, I’m not planning to seal/attach at the bottom, only the sides and top. Good idea to fill the bottom channel with sealer a day before installing the rubber flap. This design will drain and seal at least as well as original. |
| My firewall is painted, now Im trying to either re-engineer the way the cold air box is mounted to not allow water to sit or put a drain in.
I filled the bottom stuff so the water cant sit on the lower lip. I will also put some flaps on it to stop fumes from coming in the cold air flap.
I will water test it all before i start wiring and put the firewall padding in.
i have already used seam sealer at the top of the cowl... they dont mention the cold air box seal? it has a lip but what about water that gets inside? not sure it can yet, I dont think it can sit in there because of the angle.
https://youtu.be/hcGOb3nGz7o?t=179
