how to check a 56 plymouth speedometer?
jerrybev
Posted 2019-07-20 10:36 AM (#585022)
Subject: how to check a 56 plymouth speedometer?
500100252525
hi
I have an extra speedometer for a 56 Plymouth and want to know if it is any good. How to verify? I notice there is a hole on back side. Should I take a small phillips or a small flat head screw driver? (which one?) and stick it in and try to turn it slowly clockwise and see if it is stuck/moving?
thank you
jerry whitfield
Posted 2019-07-20 11:28 AM (#585023 - in reply to #585022)
Subject: RE: how to check a 56 plymouth speedometer?
500020002000500100100100100
You could put a screwdriver bit into a drill chuck and spin the speedo with the drill (get the direction correct first).
Posted 2019-07-20 12:38 PM (#585025 - in reply to #585022)
20001000500100100252525
The hole is .104" square. For testing purposes, 1000 rpm is 60 mph and 1000 turns is one mile on the odometer.
jerrybev
Posted 2019-07-21 2:01 PM (#585052 - in reply to #585023)
500100252525
hi
thank you, should I use a flat head or phillips screw driver bit?
Jerry
Posted 2019-07-21 2:17 PM (#585053 - in reply to #585052)
jerrybev - 2019-07-21 11:01 AM
Whatever fits nuggly. I suspect that a small(er) Phillips would work best.
Posted 2019-07-22 12:21 PM (#585087 - in reply to #585052)
With a piece of steel rod and a bench grinder you can make a square drive shaft that will fit the hole better than a screwdriver tip.
