57 Desoto disc spindles?
highpockets
Posted 2019-08-26 6:00 PM (#586599)
Subject: 57 Desoto disc spindles?
100100100252525
I have a 57 Desoto here with the front spindles missing. Instead of trying to find stock spindles, I would like to find later disc types. But, I have read about different height spindles changing the geometry. Are there any later ones that are bolt ons?
Posted 2019-08-27 1:30 AM (#586617 - in reply to #586599)
Subject: Re: 57 Desoto disc spindles?
5000
search on it, there are some that work, requires grinding some parts which i dont like. Spindles should be cheap from Big M. I think it changes the geometry a bit also.
I would go stock with Scarebird or AAJ.
highpockets
Posted 2019-08-27 10:08 AM (#586631 - in reply to #586617)
100100100252525
Thanks, I have looked at the scarebird brackets and that seems like a good price if I put stock spindles back on. I was hoping to find replacement disc spindles that were correct in height. I will do some more research. Thanks for your reply.
Posted 2019-08-27 12:47 PM (#586644 - in reply to #586631)
20001000500100100252525
Many have used the later F, M, J-body spindles and disc brakes. The spindles aren't the original height but the front can be aligned with them.
(discs1 (Small).JPG)
(discs2 (Small).JPG)
Attachments discs1 (Small).JPG (64KB - 171 downloads)
Attachments discs2 (Small).JPG (67KB - 173 downloads)
highpockets
Posted 2019-08-27 6:19 PM (#586671 - in reply to #586644)
100100100252525
What is the diameter on those rotors? Thanks in advance.
Posted 2019-08-28 1:29 PM (#586706 - in reply to #586671)
I think the rotors are 11", clear 14" wheels.
