Posted 2019-11-18 11:19 AM (#590329) Subject: correct ohms for fuel tank sender 59 dodge CR
Is this correct fuel tank sender for my 59 dodge custom royal ? From Vans auto in waupon wi. appears to be indenticle to old junk unit . I seen another unit that had different ohms numbers . These guys at vans auto are Mopar gurus and should know there stuff.
Mopar 57 58 59 Chrysler Dodge Plymouth Gas Fuel Tank Sending Unit 100-15 OHM
Posted 2019-11-18 11:28 AM (#590332 - in reply to #590329) Subject: Re: correct ohms for fuel tank sender 59 dodge CR
Measure the response on your gauge, but all the '57-'58 Chrysler, DeSoto, Dodge & Plymouth that I have dealt with used 215 ohm senders. There are multiple versions of these for some reason and most have the wrong range.
