I know about the different Carter part numbers voor the D500 4BBL. Early 1957 D500 had the 2532S. The 2622S came later. This set comes from a september 1956, model 1957 D500. Modifications for the 4BBL were released in the March 29th 1957 Technical Service Bulletin. The recommendation was to change the metering rods for the D500 2532S to the specifications of the later released 2622s. After these early versions and the change of metering rods, a part number change was needed to identify the difference in metering, hence the 'new' 2622S. The one listed here, had the service performed and has all the correct metering rods. I also have the correct March 1957 date coded 2622S tag. (also have a set of 1957 Plynouth Fury Dual 4BBL Carters, 2x4)
Edited by D500Jim 2020-10-09 9:25 AM
Attachments ---------------- WhatsApp Image 2020-10-09 at 14.37.35.jpeg (221KB - 125 downloads) WhatsApp Image 2020-10-09 at 14.39.45.jpeg (41KB - 113 downloads)
