3 speed w/ Borg Warner overdrive setup - $600 OBO
jboymechanic
Posted 2020-10-21 2:40 PM (#604745)
Subject: 3 speed w/ Borg Warner overdrive setup - $600 OBO
2000100252525
Trying to clear out space and raise money to pay a shop to finally finish my Imperial after spending way too much time on it to not be finished. I have a 1959 Plymouth 3 speed overdrive in what I believe is usable condition. I opened the trans and all the gears and everything appeared to be damage free, rolls over smooth in all gears. I've tested the solenoid and confirmed it works. I have the bellhousing, clutch fork, z bar, pedal linkage, flywheel, clutch disk, pressure plate, release bearing and an aftermarket control cable to use this with a 318 poly V8. I don't have all of the other electronic switches, but those are available aftermarket. The parking brake shoe will need to be replaced along with some of the springs in the brake linkage. I was going to put a 318 and this trans in my '61 Plymouth Savoy, but I will probably sell that car as well. Pictures of the transmission are in the thread linked below. $600 OBO for the whole setup. Make an offer, worst I can do is say no.
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=71289&...
jboymechanic
Posted 2021-03-25 4:58 PM (#610358 - in reply to #604745)
Subject: Re: 3 speed w/ Borg Warner overdrive setup - $600 OBO
2000100252525
SOLD.
