Location: So. Cal | I've decided to keep the yellow Fury and sell this white one. This one is definitely the best and most complete of the three that I purchased. It's an original California car with its correct '63 issued matching pair of black plates. I have an actual pink slip for the car with the plate numbers on it, that's how old the title is. I have a working pair of keys for the doors & ignition. I don't have the trunk/glove key yet. I have the missing hood letters, NOS underhood trim & trim corners for it and I have replaced the broken driver's side window. The front disc brakes work really well. The motor in it has some crud built up inside the cylinder that is preventing it from doing a complete turn, but you likely could get it to run if you remove the heads and clean it out. Being a '64 318 means it isn't compatible with the powerflite currently in the car. I have a complete '58 318 instead if that is preferable, but my original plans involved swapping the trans out for a later 727 push button. It needs some welding repair done on the left front rocker area along with typical issues at the lower front quarters, and I can do that if the buyer doesn't feel capable. I'm in no hurry to sell it, and I may just fix it further before I sell, but if you are interested, send me an email. My email address is in my profile.
Edited by Powerflite 2021-06-11 12:27 PM
(56Fury White Front Assembly.jpg)
(56Fury White Leveled.jpg)
(56Fury White Heater Box.jpg)
(56Fury White Disc Conversion Complete.jpg)
(56Fury White Floors Primed.jpg)
(56Fury White Dash Cleaned.jpg)
(56Fury White Poly Temp Install.jpg)
Attachments ---------------- 56Fury White Front Assembly.jpg (139KB - 284 downloads) 56Fury White Leveled.jpg (138KB - 274 downloads) 56Fury White Heater Box.jpg (174KB - 271 downloads) 56Fury White Disc Conversion Complete.jpg (179KB - 263 downloads) 56Fury White Floors Primed.jpg (189KB - 279 downloads) 56Fury White Dash Cleaned.jpg (180KB - 272 downloads) 56Fury White Poly Temp Install.jpg (217KB - 287 downloads)
are you the person I sold PLYMOUTH hood letters to?
thanks
Jerry Whitfield
winston salem NC |
Location: So. Cal | It wasn't me, but I could use some if you have any extras. |
let me know what hood letters you still need.
Jerry at jerrybev1@yahoo.com |
Location: Ponder, TX | Jerry, a friend is looking for a complete set of letters, if you still have any to sell. |
