Reverse only when car is warmed up.
ram250098
Posted 2022-07-08 5:13 PM (#622727)
Subject: Reverse only when car is warmed up.
I have a 58 Fireflite. I only seem to have reverse when the car is warmed up. She starts great and all forward gears work even low. But put it into reverse and nothing. Wait a few minutes and it will pop in. Fluid is clean and at the right level.
Could this be needing a band adjustment. it has been getting worse over the last couple weeks.
Thanks all
AL
Posted 2022-07-08 7:06 PM (#622729 - in reply to #622727)
Subject: Re: Reverse only when car is warmed up.
500020002000500100252525
A band adjustment isn't likely to help as it is the same adjustment for reverse and low.
Shep
Posted 2022-07-08 8:30 PM (#622731 - in reply to #622729)
20001000100100100100
The seals in the servo are most likely bad and seal better as warm fluid expands them just enough to apply the band.
ram250098
Posted 2022-07-08 9:14 PM (#622732 - in reply to #622727)
Thanks...after checking again it does have touch to much fluid on the dipstick maybe I will drain a bit out and see if it helps.
Is it just a seal or the whole reverse servo piston?
Also just realized I put in full synthetic oil...could this be the difference?
Thanks again
AL
Edited by ram250098 2022-07-09 8:39 AM
Posted 2022-07-09 1:58 PM (#622746 - in reply to #622731)
20001000500100100252525
Shep - 2022-07-08 5:30 PM
I agree, and don't confuse 1st gear in Drive with manual Low (1).
Mr. Bob
Posted 2022-07-09 2:08 PM (#622749 - in reply to #622727)
Try putting a bottle of Trans X in. It softens the internal trans seals. I had a 57 Dodge that would sometimes take a few mins to engage in Drive. Trans X fixed it.
ram250098
Posted 2022-07-09 4:10 PM (#622757 - in reply to #622727)
Thanks Bob it is amazing the difference in opinions on what to use for fluid. I read many posts and not really a solid choice. I drained the fluid as I was not sure what was in it when I bought it and had added some ATF synthetic as well . I filled it with Type F and I noticed a huge difference right away. I really don't think the trans likes the new synthetic stuff.
