Rear axel swap
jeff b
Posted 2023-03-18 11:43 PM (#628348)
Subject: Rear axel swap
Hello,
Has anyone put a B body rear end from a 1964 Plymouth into a 1958 Plymouth? Any issues
Thanks
Shep
Posted 2023-03-19 11:08 AM (#628355 - in reply to #628348)
Subject: Re: Rear axel swap
20001000100100100100
65 is a better choice, you have the easily removable drums and slightly stronger axles. Not sure about width, easy to check that online. Also make sure it comes out of an 8 cylinder car.
Edited by Shep 2023-03-19 11:10 AM
Posted 2023-03-19 12:15 PM (#628358 - in reply to #628348)
500020002000500100100
The B-body axle is a little narrower, so if you use that, you will need deeper dish wheels. Otherwise, use the '65-'69 C-body axle instead.
jeff b
Posted 2023-03-19 12:38 PM (#628361 - in reply to #628348)
Ok thanks really appreciate it. I was concerned about pinion angle as well, and driveshaft compatibility. Look like I need to find a C Body rear
Shep
Posted 2023-03-21 8:47 AM (#628406 - in reply to #628361)
Pinion angle set when the spring perches are welded in or moved as necessary.
Posted 2023-03-21 2:07 PM (#628414 - in reply to #628348)
Subject: RE: Rear axel swap
20001000500100100252525
The '65-'67 C-body rear end is a better choice, the pinion angle is correct and the spring perch spacing is close enough for a drop-in...no welding required.
chstrumpetdude
Posted 2023-03-21 4:58 PM (#628421 - in reply to #628348)
I also understand that certain E-body is acceptable, but the pinion angle is off by 3 degrees. I could not find a C-body for my car, but did find a cheap 71 E-body
Shep
Posted 2023-03-21 5:51 PM (#628422 - in reply to #628421)
Pinion angle is dependent on the height of the front suspension so there are still variables in this issue, slip yoke driveshaft s have a different procedure then the old style shaft. Until the car is at ride hgt., it is impossible to get an accurate measurement on the final pinion angle, if off at this point, wedge shims can correct it.
Edited by Shep 2023-03-21 9:39 PM
matador440
Posted 2023-03-24 5:03 PM (#628491 - in reply to #628422)
500100252525
I have used E body rears about 15 times they work great . They bolt right in. You can get a 3 degree shim off ebay and install it when you are installing the rear. With the c body rear you have to re weld and move the spring perches on the housing. With the ebody you can also move your emergency brake cable to the rear wheels ( MUCH SAFER). You can also use your original wheels with this conversion. OVER ALL ITS A NICE AND SAFER IMPROVEMENT. With this e body you now you can use any gear ratio 3rd member and not have to pull the drums with a puller-- just slide off the drums .
Posted 2023-03-24 6:10 PM (#628495 - in reply to #628348)
You realize that the only difference between the '65-'69 Cbody and '70-'74 Ebody rears is the pinion angle. That's it - along with maybe different length e-brake cables. All the things you mention are the same.
57plymouth
Posted 2023-03-25 7:43 AM (#628511 - in reply to #628495)
20001000500252525
Powerflite - 2023-03-24 6:10 PM
Plus, there were more C bodies built and less E bodies. The muscle car builders would prefer the E body stuff so the C body axle would be more common and cheaper.
Apollo 61
Posted 2023-03-25 8:48 PM (#628534 - in reply to #628348)
5001001002525
How does a 70 C body rear end work in?
Posted 2023-03-25 10:46 PM (#628537 - in reply to #628348)
1970 C-body rears became much wider.
(8_3-4Axles.jpg)
Attachments 8_3-4Axles.jpg (140KB - 68 downloads)
Posted 2023-03-26 3:31 PM (#628554 - in reply to #628495)
Powerflite - 2023-03-24 3:10 PM
And the location of the vent hole, not a big issue but it affects the brake hose length.
'70-'74 E-body housing: Vent bolt location: 11.25" from center of housing
'65-'69 C-body housing: Vent bolt location: 7.75" from center of housing
Posted 2023-03-27 11:46 AM (#628570 - in reply to #628348)
Thanks for that info Chizler. That provides a convenient way to figure out which axle you really have. Do you have a suggestion for a brake hose to use with the C-body housing? I have always resorted to moving the body mount to get it closer. There is also the '65-'70 A100 van which can be confused between them. Do you know of any differences between that one and the others?
Posted 2023-03-27 2:17 PM (#628577 - in reply to #628570)
When I swapped a C-body into my '57 I just measured the required length for the hose to reach the fitting and clear the non-stock exhaust and found a hose with the needed end fittings.
Don't know much about the A-100 other than the width but I imagine the spring pad spacing is different. Don't know where the breather is located.
Despite the cost of living, have you noticed how it remains so popular?
(CIMG0624 (Small).JPG)
Attachments CIMG0624 (Small).JPG (144KB - 65 downloads)
