I elevated vehicle and verified my rear end # 1141544N1. Can you verify that this is a 8 3/4 or 8 1/4 based on the #? Mine is an 11 bolts in housing, either 339 or 389 is on side.
thank you for your help
Jerry
Jerry Whitfield |
Location: Alaska | If it is the original rear it is the 8 1/4" since that is the only one used under 56 Plymouths. |
The 11 bolts is a giveaway, the 8 3/4" has 10. |
