‘57-‘58 Plymouth power steering wheel hub
Trogdor
Posted 2023-11-18 2:08 PM (#632763)
Subject: ‘57-‘58 Plymouth power steering wheel hub
Looking for just the center hub. I have a good wheel and horn ring. Please let me know if anyone has one they’ll part with. Thanks!
finsruskw
Posted 2023-11-18 6:09 PM (#632766 - in reply to #632763)
Subject: Re: ‘57-‘58 Plymouth power steering wheel hub
2000100100252525
Do you mean the center steering rod, with the spline on the end?
First off, you need to do some homework here because we need to know what "type" steering unit you have.
Either the coaxial type.....
Or the constant control type "up to models"......
Or, the constant control type "1958 after model"
http://www.jholst.net/55-58-parts-manual/steering.pdf
Edited by finsruskw 2023-11-18 6:19 PM
Posted 2023-11-19 12:42 AM (#632768 - in reply to #632763)
Subject: RE: ‘57-‘58 Plymouth power steering wheel hub
500020002000500100100100100
Are you looking for something in this parts diagram?
Posted 2023-11-19 12:48 AM (#632769 - in reply to #632763)
I would guess he is looking for a hub to mount an aftermarket steering wheel.
Posted 2023-11-19 2:57 AM (#632770 - in reply to #632769)
Powerflite - 2023-11-18 9:48 PM
Not sure about 57-58 Plymouths but when Phil L. was looking for a hub for an aftermarket steering wheel for his 55 Dodge wagon,
I cut up my spare "core" steering wheel and sent the center section to him to work up a hub.
The issue with the 55-56 Dodges (at least) is there is a special spline spacing such that the wheel only fits in one orientation, i.e. it
can NOT be "clocked" to eliminate/correct alignment centering issues.
(DaveFsSpareSteeringWheelCoreBeforeBeingCut.jpg)
(DaveFsSpareSteeringWheelCoreAfterBeingCut.jpg)
Attachments DaveFsSpareSteeringWheelCoreBeforeBeingCut.jpg (229KB - 36 downloads)
Attachments DaveFsSpareSteeringWheelCoreAfterBeingCut.jpg (231KB - 42 downloads)
Trogdor
Posted 2023-11-19 8:14 AM (#632776 - in reply to #632766)
Sorry guys, I must have called it the wrong thing. I mean the bullet-shaped chrome trim hub that screws onto the horn ring. The one that says Power Steering on it.
Posted 2023-11-19 1:35 PM (#632781 - in reply to #632776)
So like the one in the center of this Fury steering wheel?
Trogdor
Posted 2023-11-19 3:36 PM (#632785 - in reply to #632781)
56D500boy - 2023-11-19 1:35 PM
Yes, exactly.
coronetx2
Posted 2023-11-25 3:55 PM (#632858 - in reply to #632763)
100252525
I may have an extra let me do a little digging
