1959 Dodge 361 low deck engine.
It's been fully reconditioned.
I'm just dong a pressure check on the coolant system.
I have coolant leaking past the front two exhaust manifold bolts on the generator side.
Has anybody ever heard of this before?
Posted 2024-05-01 9:04 PM (#634979 - in reply to #634978) Subject: Re: Coolant leak from exhaust manifold bolts
Posts: 9748 Location: So. Cal
Yes, the exhaust bolts go through to the coolant. All of them do. So it's amazing that you only have 2 problems. I recommend taking them all out and using hi-temp silicone or other sealant on the threads before inserting them back in. Drain the fluid first, of course.
Posted 2024-05-01 9:49 PM (#634980 - in reply to #634979) Subject: Re: Coolant leak from exhaust manifold bolts
Posts: 310 Location: Newcastle Australia
Powerflite - 2024-05-02 11:04 AM
