Location: Uniontown, Pa. USA | Every tine I try to upload a picture for the fury belt buckle it says it failed because of to big over 200KB. Then it says this can be solved by editing the metabase.xmi on the server. Modify the AspMaxRequestEntity Allowed value to the desired value? I must apologize Dave but I'm completely lost here can you help?
Thanks
Paul |
Location: Omaha Nebraska USA | Use a graphics program to reduce the size.... I assume you don't have Photoshop or something similar (that would be the easy way)
all PCs have "Paint" under "Accesories" you reduce the size of the image, unfortunatly you can't play with the quality
Open the image in Paint
click on "Image" then "resize/skew"
change bothe height and width to something like 80% Click "OK"
Click "File" then "Save as..."
(paint2.png)
Attachments ---------------- paint2.png (232KB - 825 downloads)
Location: Snohomish, WA. | If you have XP or VISTA, email them to yourself and select the medium pic size. They come back downsized automatically.
Mike |
Location: Arvada, Colorado (NW Denver Metro Area) | Mike, thanks for the tip if you have Vista. This works! |
Location: Yorba Linda, Ca | Something strange going on John, I did not have to resize those pictures to post them here, and in fact the Desoto is only 55KB so not sure what was up when you tried to load them. I did have to resize mine as they were are well over 250KB.
Hmm now reading that post about emailing them----maybe that is why they were not too big when they got here?
I use Paint to resize mine, it's probably one of the easiest programs to use for that.
Gary |
Location: Milwaukee Wisconsin | trying to post a pic downsized
success !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Edited by dodge59 2013-03-20 12:15 AM
(bal trimmed.JPG)
Attachments ---------------- bal trimmed.JPG (23KB - 705 downloads)
