Greg Leggatt's Forward Look Art Gallery Thread Jump to page : 1 2 3 4 5 6 Now viewing page 6 [50 messages per page] | View previous thread :: View next thread |
soiouz |
Expert Posts: 3480 Location: Montreal, Canada | LD3 Greg - 2016-02-07 7:06 PM David, I knew there was a good reason to save it all those years ago!! Greg Oh thanks, Greg! I'll pick it up at your place some time this year! | ||
miquelonbrad |
Expert Posts: 1737 Location: Hay Lakes, Alberta, Canada | Neat pics of the wiring harnesses being built. Good to see where mine came from. | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | Thanks, Brad. Really busy for the last few months. A lot of cars being restored at this time. Greg | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | As I recall, I've only had a couple of these orders. All the wiring for a 60 Sport Fury Sonoramic Convertible. It is hard to zoom in on multiple layers, but, here goes. All original style PED plastic connectors and terminals. All NEW, nothing recycled!! Greg (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (189KB - 289 downloads) image.jpg (121KB - 297 downloads) image.jpg (123KB - 280 downloads) image.jpg (109KB - 292 downloads) image.jpg (85KB - 275 downloads) | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | There is a significance to the last pic. Some time ago, I wrongly argued on a thread with Mick (totired) that the Hi-beam indicator light wire should be red not white for 60 Ply. Here is the proof that I conceded the point!!! Greg | ||
Sahnu |
Regular Posts: 83 | Hi Do you do Imperial 1959 electric cables. I would like to order. Thanks Olli ? | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | Ollie, I don't have anything for 59 Imperials. Thanks, Greg | ||
d500dodge59 |
Veteran Posts: 245 | greg this is jan what olli need is the power window wiring harnes you made them for me dont you have the patern for it he need one without the power doorlocks JAN | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Wow Greg The wiring harness in your pictures looks really great. I assume you'll build 300F wiring harnesses as well? The wiring harness in my 300F (the Letter) looks good, but all the brass contacts are badly corroded. Happy Restoring! I will not give up restoring my Letter until it's finished. Dieter | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | d500dodge59 - 2016-09-10 3:57 AM greg this is jan what olli need is the power window wiring harnes you made them for me dont you have the patern for it he need one without the power doorlocks JAN Jan, you sent me patterns and I sent them back to you. I didn't keep anything because I don't want to do 59 imperial wiring! Greg | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | di_ch_NY56 - 2016-09-10 8:39 AM Wow Greg The wiring harness in your pictures looks really great. I assume you'll build 300F wiring harnesses as well? The wiring harness in my 300F (the Letter) looks good, but all the brass contacts are badly corroded. Happy Restoring! I will not give up restoring my Letter until it's finished. Dieter Thanks, Dieter, I do 300F wiring all the time. email me, ggleggatt@gmail.com Thanks, Greg | ||
d500dodge59 |
Veteran Posts: 245 | ok did you allso send the old ones i havent take it out of the box yet | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | d500dodge59 - 2016-09-13 1:30 AM ok did you allso send the old ones i havent take it out of the box yet I think so!! | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | Another rather rare but very functional 57-59? accessory was an underhood light. The only one I recall seeing was on a 58 Dodge in a salvage yard. Here it is installed on my Regal. The pink power wire comes directly from the "AUX" terminal of the headlight switch and the base of the underhood light socket is a Mercury switch. | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | My photos were too big!! !!! PITA Greg (image.jpg) (image.jpg) Attachments ---------------- image.jpg (222KB - 180 downloads) image.jpg (313KB - 156 downloads) | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | Pink wire; is it not just a trunk light+switch added to the car? Or was it actually an option? This is my favorite thread on the entire site. There is a lot of hard-earned accurate information for anyone willing to spend a few moments to absorb it. Thanks Greg! | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | Thanks, Danny! That thread spans a bunch of years. I'll get a photo of the trunk light next time I'm at the car. Greg | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | Here is the trunk light. A completely different bracket. The underhood light bracket could probably be rebent and cut to become a trunk light but not the other way around. The "pink wire" circuit is an interesting one. It does vary from year to year and model to model but for 58 Dodge it powers a number of lights. It is battery power, through a circuit breaker within the headlight switch to the "aux" gang on the switch. Powers brake lights, dome lights, map lights, glovebox light, radio lights, trunk light as well as the underhood light if equipped. As long as the battery is connected pink wires are "hot". Greg (image.jpg) Attachments ---------------- image.jpg (184KB - 172 downloads) | ||
