Tire size for 56 wagon
56longroof
Posted 2019-05-13 12:18 PM (#582105)
Subject: Tire size for 56 wagon
What tire size do you guys recommend for my bone stock 56 wagon. it has bias ply whitewalls on it now and want to upgrade to wide white radials.
Posted 2019-05-13 1:24 PM (#582111 - in reply to #582105)
Subject: RE: Tire size for 56 wagon
500020002000500100100100100
I am running 235/75/15 radials on 7" wide 85 Dodge Diplomat cop car wheels on my 56 Dodge sedan. I had to trim the inside of the rear wheel well opening lip by about 3/4" to do so. I recently noticed that I am getting some rubbing on that lip and also on the inside front by the tie rod ends. I think the issue is the side walls are not very stiff and they are "bending" on corners, causing the rubbing. Normally going straight, no issues.
Bottomline: for my situation, I think 215/75/15 would have been a better choice.
I have posted info about wheel sizes and both bias and radial tire sizes but I can not search and give you the link on this tablet (no mouse)
If I went wide white wall radials I would investigate Diamondback.
Good Luck
56longroof
Posted 2019-05-15 11:13 AM (#582165 - in reply to #582105)
Subject: Re: Tire size for 56 wagon
Do you think 225/75/15's would fit without rubbing?
Posted 2019-05-15 12:39 PM (#582168 - in reply to #582165)
20001000500100100252525
Tire fitment isn't just about the tire size but also the wheel offset and back spacing. Since a '56 wagon originally came with 7.10 X 15 tires, the modern equivalent is P215/75R-15. With stock wheels the 225 shouldn't be a problem.
brand209
Posted 2019-05-15 6:21 PM (#582175 - in reply to #582168)
I have 225/75/-15s on my 56 savoy currently no problems with my car
