14 inch inch disc brake rims
Apollo 61
Posted 2019-06-22 12:38 AM (#583858)
Subject: 14 inch inch disc brake rims
10010010010025
Is there a 14 inch rim that will work on a disc brake conversion? I want to use full size original 14 inch hubcaps.
Posted 2019-06-22 8:43 AM (#583865 - in reply to #583858)
Subject: Re: 14 inch inch disc brake rims
50005001001001001002525
Stolen from charger forums 2012:
Re: Disk Brakes with 14" Vector Wheels
« Reply #5 on: October 02, 2012, 10:21:08 AM »
We run into this with the '58 Plymouths and the F. Look cars. Rule of thumb is if the wheel was manufactured, or manufactured for DRUM braks, Disc's WILL NOT FIT...If the 14" wheel was manufactured for Disc brake cars then your ok... Like newer A/B bodies with our bolt pattern.
