disc brake conversion for a 58 Belvie
lonesome mopar
Posted 2019-08-22 12:36 PM (#586394)
Subject: disc brake conversion for a 58 Belvie
100100100252525
Hi gang !
I am sure some among you could tell me if this kit could fit my 1958 Plymouth belvedere 4DRHT....
https://www.ebay.com/itm/Mopar-Chrysler-Plymouth-A-body-front-power-disc-brake-conversion-5-on-4-chrome/332347810339?epid=1154173226&hash=item4d61792223:g:sAgAAOSwetRZle8D
Posted 2019-08-22 1:16 PM (#586396 - in reply to #586394)
Subject: RE: disc brake conversion for a 58 Belvie
500020002000500100100100100
lonesome mopar - 2019-08-22 9:36 AM
Hi gang! I am sure some among you could tell me if this kit could fit my 1958 Plymouth belvedere 4DRHT....
https://www.ebay.com/itm/Mopar-Chrysler-Plymouth-A-body-front-power-...
And with the stroke of the ENTER key (AND removal of the unnecessary html formatting BS, I've magically made that link ALIVE!
I'm pretty sure that it is not for you for several reasons.
"Mopar Chrysler Plymouth A body front power disc brake conversion 5 on 4 chrome" is not a 58 Plymouth.
Edited by 56D500boy 2019-08-22 1:21 PM
Posted 2019-08-22 2:40 PM (#586401 - in reply to #586394)
Subject: Re: disc brake conversion for a 58 Belvie
5000200020005001002525
Wrong bolt pattern and wrong geometry. Get one from:
https://scarebird.com/index.php?route=product/product&path=64&produc... (15" wheels required)
or http://www.aajbrakes.com (stock 14" wheels)
Willwood is another higher end option (15" wheels required)
Edited by Powerflite 2019-08-22 2:43 PM
BlueGhost
Posted 2019-08-22 4:23 PM (#586403 - in reply to #586401)
Powerflite - 2019-08-22 1:40 PM
It looks like Scarebird has changed the rotors and calipers to ones that work with 14 inch wheels.
We use 1977 Cordoba rotors (11-3/4", same wheel bolt pattern and pilot size) and 1985-89 Cadillac DeVille FWD front calipers. This kit will clear your OEM 14" rims.
Mopar1
Posted 2019-08-23 9:46 AM (#586442 - in reply to #586403)
2000100025
On my '60 Plym I used '77 NYer spindles & a late '70s Ranchero 9" axle. Had ordered Aspen/Volare spindles from a guy, they wouldn't fit, but I'm not sure if he sent wrong ones or what, they were supposed to fit.
lonesome mopar
Posted 2019-08-23 12:09 PM (#586446 - in reply to #586394)
100100100252525
Thanks a lot Dave!
I always mess up with font size and links color.
I tried to make the the fonts bigger because FWL fonts are too small for my weary eyes....Thank you very much for your help !!!
Thanks all the friiends for the hints.
Unfortunately down here it is not easy to access all the parts suggested...
I will check the link suggested.
Thanks to everybody !!!!
wayfarer
Posted 2019-08-25 1:59 PM (#586547 - in reply to #586394)
500100100100252525
Also check with www.rustyhope.com
lonesome mopar
Posted 2019-08-27 12:06 PM (#586642 - in reply to #586394)
100100100252525
thank you wayfarer !!
this site is complete and very instructive.
Thumbs up !
