1955 Eaton Power Steering Pump
Imp1955
Posted 2019-10-16 2:56 AM (#588890)
Subject: 1955 Eaton Power Steering Pump
I am searching for technical informations on the Chrysler/Imperial power steering pump.
I own a 1955 Imperial custom with the power steering pump labelled Eaton.
I would need technical informations like schematic, technical drawings, parts lists, an exploded view to repair a substitution pump.
If possible, spare parts or a rebiuld kit would be even better.
Anything like photos, sanned documents would be appreciated.
Posted 2019-10-16 8:40 AM (#588893 - in reply to #588890)
Subject: RE: 1955 Eaton Power Steering Pump
500020002000500100100100100
Something like this thread:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=72341&...
And you should have the Factory Service Manual. If you don't, for the power steering pump info you could go to Mymopar.com and download the 55/56 Plymouth manual. Should be something in it.
http://www.mymopar.com/index.php?pid=109
Or maybe, simply go here:
http://www.imperialclub.com/Yr/1955/index.htm
and here:
http://www.imperialclub.com/Repair/Lit/Master/index.htm#1955
Edited by 56D500boy 2019-10-16 8:46 AM
