Front disc rear drum brakes 1961 Plymouth Savoy
jboymechanic
Posted 2019-10-20 11:16 PM (#589058)
Subject: Front disc rear drum brakes 1961 Plymouth Savoy
2000100252525
I'm getting ready to update the brakes in my '61 Savoy, here's what I have:
-Front disc kit from AAJ
-Cordoba rotors and bearings
-GM calipers, pads and hoses
-stock rear drums
-early 1980s Cordoba dual res mastery cylinder (no residual valves)
My only real question is, what residual or equalizing valve do I need for the rear drums. If I could find it, I would use the valve from the 1980s Cordobas as well, but I don't know how/where to get a new one.
Shep
Posted 2019-10-21 8:32 AM (#589062 - in reply to #589058)
Subject: Re: Front disc rear drum brakes 1961 Plymouth Savoy
20001000100100100252525
How about a proportioning valve from the Cordoba ?
StillOutThere
Posted 2019-10-21 9:43 AM (#589065 - in reply to #589058)
2000100010010025
Parts house new adjustable valve and you can dial it in very simply.
Posted 2019-10-21 12:38 PM (#589074 - in reply to #589058)
Subject: RE: Front disc rear drum brakes 1961 Plymouth Savoy
20001000500100100252525
I would but an RPV in the rear brake circuit and wait on the prop valve until you can test the system for premature rear lockup.
Posted 2019-10-21 12:41 PM (#589075 - in reply to #589065)
5000
StillOutThere - 2019-10-21 9:43 AM Parts house new adjustable valve and you can dial it in very simply.
what he said!
Mopar1
Posted 2019-10-23 11:49 AM (#589156 - in reply to #589075)
2000100025
On my '60 Plym I used '77 NYer spindles & calipers, a 9" rear, a later in the '60s disc/drum M/C & a Summit proportioning valve.
