RESISTOR Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | i have a pointed distributor in my dart and need a resistor . what should the resistance value be . i've seen em from .25 to @ 1.6ohms . the one that bit the dust was what i believe to be oem with one nutted post and one push on . can't seem to find any real info on what to use . it's the first one in over 50 yrs of driving these clunkers i've had to change one . soon , probably spring i'll be going to electronic conversion but i really need the car mobile now and break in after rebuild do to wrist pin freeze up----------------------------------------------later the distributor is a 69 Edited by 60 dart 2019-11-05 1:28 AM | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Seems like the same capacitors was used to many applications Chuck - heres some https://www.rockauto.com/en/catalog/dodge,1969,dart,6.3l+383cid+v8,1... | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | thanks wiz but thats not it , maybe ballist resistor would be a better term ....... something like this example below https://www.ebay.com/itm/1-6-OHM-Ignition-Coil-External-Ballast-Resi... | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Ok Chuck, any ballast resistor from a V8 would practically do, most important is that the voltage drops to 7-8 volt after the resistor. Check these ones https://www.rockauto.com/en/catalog/dodge,1969,dart,6.3l+383cid+v8,1... | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | thanks buddy ,,,,, from what i've been able to sum up today is that the optimum added up OHM value of both the ballist resistor and coil is 3 OHMS , 1.5 for each gets me where i need to be . so i just checked my mallory coil and it tests at 1.5 . then i checked the new ballist included in my pointless ign conversion and its 1.5 , adding up to the optimum of 3 OHMS . what i was really wondering by my question though , is will a new/nos oem ballist resistor measure up with the newer mallory coil , considering it needs to be 1.5 as is my coil or were the older oem less/more than 1.5 . oh , and the older coil i have is also 1.5 , "all at high side"--------------------------------------------------later | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | I measured a spare "Ignition Parts" A1101 (replaced by C1101) ballast resistor Chuck and it was 0,7 ohms cold resistance. The Standard Motor Products RU11 Resistor has a cold resistance of 0,5-0,6 ohms and an operating resistance of 1,75 ohms. | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | below is a match to the one i need and bought being it matches the oem wiring setup . one plug . one bolt on -----------------------------------------------------later https://www.ebay.com/itm/Mopar-1960-Coil-Resistor-12v-Cole-Hersee-30... | ||
