Door Handle assembly
plymouthred
Posted 2019-11-11 1:59 AM (#590000)
Subject: Door Handle assembly
Got my door handles rechromed on my 58 Imperial. They came back all disassembled. Originally they were rivited together so opinions on how you put yours back together. I thought the obvious and just bolt them back together but I liked the way they were rivited. Opinions on what you did with yours. Pic of my rechromed one and a rivited one FYI
Chris
Edited by plymouthred 2019-11-11 2:02 AM
(Imperial door handle 1.JPG)
(Imperial Door Handle.JPG)
Attachments Imperial door handle 1.JPG (29KB - 118 downloads)
Attachments Imperial Door Handle.JPG (36KB - 130 downloads)
ronbo97
Posted 2019-11-11 10:19 AM (#590008 - in reply to #590000)
Subject: RE: Door Handle assembly
2000200025
Have a machine shop reinstall the rivets. If you use bolts, they may loosen up over time, which may result in the inability to open the door.
Ron
Posted 2019-11-11 10:43 AM (#590011 - in reply to #590000)
Subject: Re: Door Handle assembly
5000
you could weld the nut on the backside. or punch it,or pin it. lots of way to get a nut stuck on a bolt
dodge59
Posted 2019-11-11 10:58 AM (#590014 - in reply to #590000)
1000
special nuts at hardware that have the nylon in thread so the nut won't back off.
Posted 2019-11-11 11:16 AM (#590016 - in reply to #590014)
500020002000500100100100100
dodge59 - 2019-11-11 7:58 AM
That was going to be my suggestion as well. Can't tell but the choices for the bolt size are 8-32, 10-24 and 1/4"-20. Bolts can be shortened with a Dremel tool and a thin E-Z-Loc cut-off wheel.
Nyloc nuts are easy to find at Home Depot or Lowes. Install them so there is a little play, i.e. go tight and then back-off very slightly.
https://en.wikipedia.org/wiki/Nyloc_nut
https://www.homedepot.com/p/Everbilt-1-4-in-20-tpi-Coarse-Stainless-...
https://www.amazon.ca/Dremel-Cut-Off-Mandrel-Cutting-Starter/dp/B000...
Edited by 56D500boy 2019-11-11 11:19 AM
dodge59
Posted 2019-11-11 11:21 AM (#590017 - in reply to #590016)
1000
yep ........ those are the locking nuts I was refering too . Thanks  >>>
Posted 2019-11-11 12:33 PM (#590021 - in reply to #590000)
20001000500100100252525
In some cases, the nut/bolt combo won't fit in the door. On mine, I drilled and tapped the original rivets for a machine screw.
