A745 3-speed shifter
Valdez25
Posted 2019-11-21 2:53 PM (#590499)
Subject: A745 3-speed shifter
New User
Any ideas for a shifter for an A745? My transmission is casting number C99162 6AF. My column shifter is worn out. I'd like to replace it with a floor shifter. Hurst has a universal 3-speed shifter, part number 530-5010002 in Jeg's catalog. Any thoughts?
Thanks,
Greg Vallero
636-373-4177
warbirdridesusa@gmail.com
Posted 2019-11-21 3:15 PM (#590501 - in reply to #590499)
Subject: RE: A745 3-speed shifter
20001000500100100252525
Welcome to the board.
That Hurst shifter will probably work for you, you may want to look over the installation instructions before making a decision.
https://documents.holley.com/5010002.pdf
R41HP
Posted 2020-01-09 7:11 PM (#592701 - in reply to #590499)
Subject: Re: A745 3-speed shifter
1001002525
I have a Hurst shifter for an A745. The paperwork says the model for '61-'62 Chrysler, and '61 Dodge and Plymouth is DP-61. 1962 Dodge and Plymouth shows DP-62.
