57 Belvedere door jamb dome light switch
retrodaz
Posted 2019-12-07 8:23 AM (#591212)
Subject: 57 Belvedere door jamb dome light switch
Hi, the drivers door jamb switch has stopped working and no longer turns the dome light on and off. I need to pull out the switch to investigate. It looks like it unscrews easily enough. Is there a way to get to the back of the switch to disconnect the wire before I unscrew it or do I just unscrew it with the wire still attached? Thanks in advance, trying to stop a little job becoming a big one!
ronbo97
Posted 2019-12-07 8:29 AM (#591213 - in reply to #591212)
Subject: RE: 57 Belvedere door jamb dome light switch
200010001001001001002525
Just remove the kick panel and pull out the yellow wire. It's a spade-type connector that's crimped in. So twist it off.
Ron
retrodaz
Posted 2019-12-07 2:21 PM (#591229 - in reply to #591212)
Subject: Re: 57 Belvedere door jamb dome light switch
Thanks Ron, I’ll do that.
Darren
