1962 TF trans question Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | Saw this local add about a 318 Poly and TF trans and talked to the owner. He pulled these out of a driving '62 Plymouth Belvedere wagon he just bought and he is building a 426 for it. I was curious, this transmission will have the newer crank flange and use a flex plate, correct? But it will also still work with the push buttons in my 1960 Plymouth? Would this transmission have a park position? If so, how is it engaged? Owner said his '62 wagon has parking brake in the rear axle, I thought that didn't come until later? https://milwaukee.craigslist.org/pts/d/pewaukee-62-plymouth-318-poly... | ||
Expert 5K+ Posts: 9900 Location: Lower Mainland BC | . Well for sure the TF in question does NOT have the eBrake on the tailshaft so it has to be on the rear axle brake drums | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | That's the later TF 727. It always has a flex plate and needs the newer style crankshaft flange. | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | Yes, the aluminum housing gives away that it is a 1962 or newer, so it will use a flex plate as well. Is this a '63 to '65 transmission? In 1966 I think the flange output was replaced by the slip yoke. If this was a '62, it would still have 5 positions (R N D 2 1) and the parking brake on the drum, right? Again, I'm looking for a trans to go into my 1960 wagon even if it's behind a newer engine, but only if I can still use my original push buttons and parking brake. | ||
ABloch |
Expert Posts: 1476 Location: Pacific Northwest | There is a parking brake in addition to the "PARK" position on the trans in 1962. This was activated by a lever on the left side of the dash and is a separate system from the push buttons. I suppose you could run it with the park cable installed and left in the release position. however you will need to figure out an emergency brake something or other..... | ||
Handygun |
Elite Veteran Posts: 1118 Location: STL, MO | If this helps, the 62 727 with parking drum only came on the full size 62's, so no 62 Plymouths have them. | ||
Expert 5K+ Posts: 9663 Location: So. Cal | The slip yoke started in 1965, so if you wanted that, you could use that one-year only trans with your push buttons. 1966 was the first year that wasn't cable shifted. The '62 big block trans has the park brake, but it doesn't have a park function! It's an oddball. '62 transmissions from B-body cars have the park function, but they don't have the park brake on them. The two options are mutually exclusive. '63-'65 BB transmissions had the park function, along with all A-body 904's, even in 1960. If you really want both, I recommend that you get a '63-'65 big block trans with the park function, and transfer the tail shaft from another trans onto it. You can even use a later tailshaft from an RV with the park brake, and swap all the later internals into it, but keep the old valve body with the button shifter. There is a guy that builds them that way for you if you would like to purchase one already done, the 727 Specialist. But if it were me, I would use the stock trans without the park brake on it, but with the park function, and swap in a later C-body rear end to hook up your e-brake to. http://www.727specialist.com/ Edited by Powerflite 2020-01-18 5:44 PM | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | Thank you for this addition info, this is what I was looking for. I'm still considering buying this 318 poly and trans. | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | The owner of this engine and trans lowered his price so I bought them after all. | ||
Space Trukin Wagon |
Extreme Veteran Posts: 427 Location: Ohio | Jon, It’s pretty simple to properly ID the year of any mopar trans by checking the part number stamped on the pan rail. If you provide the part number on the pan rail, I can track it down for you. | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | Stamped on trans above pan: 2125122 0087008 | ||
Expert 5K+ Posts: 9663 Location: So. Cal | You have the exact same transmission that I have in my '57 New Yorker. It is from a '62 318 from the 2125122, and was built on Sept 01, 1961 (I think). It was the 8th one built that day. | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | I will most likely sell the trans as I just have too much stuff and I doubt I would go back to using a 3 speed auto. PM me if interested. | ||
Expert Posts: 3776 Location: NorCal | Powerflite - 2020-02-10 7:50 AM was built on Sept 01, 1961 (I think). FWIW, actually October 23, 1961. | ||
Expert 5K+ Posts: 9663 Location: So. Cal | How do you figure that out? Does it skip weekends or Sundays? | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | Nathan, What engine is in your '57 New Yorker and dig the engine require an adapter? | ||
Expert 5K+ Posts: 9663 Location: So. Cal | 392 hemi, and yes it requires an adapter because of the extended crankshaft. | ||
Expert Posts: 3776 Location: NorCal | Powerflite - 2020-02-10 10:05 AM How do you figure that out? Does it skip weekends or Sundays? The 10,000 day calendar started on July 29, 1961 and the subject date is 87 days later. I have an Excel file that decodes the dates. The same decoder is here: https://maxwedge.com/articles/10k.php Edited by 57chizler 2020-02-11 2:48 PM | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | So does this trans have a park function built into it? If so, how is it controlled? I only see the threaded shift cable inlet? | ||
Expert Posts: 3776 Location: NorCal | In '62 the full-sized cars still had the parking brake on the tail and were all big blocks. Any 318 would not have had the parking brake but would have a mechanical park mechanism on the bottom of the tailhousing actuated by a second cable. (parkcable-remove.jpg) Attachments ---------------- parkcable-remove.jpg (20KB - 240 downloads) | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | Ah, I thought the transmission looked odd near the back end of the pan. Thank you for the info. | ||
Expert 5K+ Posts: 9663 Location: So. Cal | It's very annoying that most of these transmissions are missing all the cables. The cables for these things aren't cheap. Even the speedometer cable is quite expensive because of how it attaches inside the trans. | ||
normsclassicradio |
Extreme Veteran Posts: 302 Location: Kalispell, MT USA | Maybe the Google album I made rebuilding my 64 TF will help. https://photos.app.goo.gl/igRdXtnsE4WuMGMr9 Norm (20190507_221343.jpg) Attachments ---------------- 20190507_221343.jpg (114KB - 292 downloads) | ||
