What's the difference? Starters
hemi68charger
Posted 2020-05-19 12:04 PM (#598471)
Subject: What's the difference? Starters
New User
Hey gang..
New to the board.. I have a friend locally here in the Houston area I'm trying to help, locate for him a proper starter for his 1961 Chrysler 300G, 413 Long ram. What makes this starter unique. Is it true 61's are different than 62-63?
Attached is a picture of the apparent starter he needs he found on the net and then the location for the starter on his particular car..
Cheers,
Troy
(414429561.jpg)
(414429562.jpg)
Attachments 414429561.jpg (45KB - 263 downloads)
Attachments 414429562.jpg (98KB - 306 downloads)
Posted 2020-05-19 3:32 PM (#598487 - in reply to #598471)
Subject: RE: What's the difference? Starters
20001000500100100252525
Welcome to the board.
The starter you need is direct drive (P/N 1889200) with no nose pilot, not unique to the 300, it was used on most '59-'61.
Starting in '62 most Mopar starters were gear reduction with a nose pilot that fits in a pocket in the bellhousing. Standard shift applications being the exception.
Edited by 57chizler 2020-05-19 3:39 PM
(Starter.jpg)
Attachments Starter.jpg (16KB - 262 downloads)
Posted 2020-05-20 1:07 AM (#598528 - in reply to #598471)
Subject: Re: What's the difference? Starters
5000200020005001002525
You can also use a mini starter from IMI. I just put one into my '58 DeSoto. See this thread: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=66444&...
RICKYMOPAR
Posted 2020-05-29 12:06 PM (#598952 - in reply to #598471)
100100252525
Did anyone notice this is a stick shift G?
wheelcover
Posted 2020-06-06 5:09 PM (#599340 - in reply to #598952)
Good notice, I had to go back and revisit the pictures. Pretty cool. Would that be a floor shift? I’d like to see interior pics.
