CONSTANT CONTROL SWAPPING INFO
22mafeja
Posted 2020-05-29 1:08 PM (#598954)
Subject: CONSTANT CONTROL SWAPPING INFO
50010025
My firedome 58 had to much internal leakage at left turns only. Almost no support power and hissing. The cylinder bore was scored and worn and require a sleeve to work properly.
Has anybody done this? The machining wouldn`t be too hard but the centering is not easy..regardless of whether it is done by metal turning or with a mill.
My old steering box was a 1733596 and the replacing one a 1822734. I was in a hurry so I didn`t notice that the steering column support collar was different sized on the boxes.
1733596 has 63,5 mm diameter and 1822734 has 57,5 mm diameter.I made a spacer of a plastic tube and that works well. I had to shorten the spring pin to be able to turn the steering axle
inside the smaller collar.
This I had to learn the hard way of course.
51coronet
Posted 2020-06-02 12:20 AM (#599084 - in reply to #598954)
Subject: Re: CONSTANT CONTROL SWAPPING INFO
1001001002525
Did you try getting in touch with Fin_ish Floyd? He does power steering upgrades and may be able to help you out.
