1959 dodge super d500 Rare rt exhaust manifold Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | Do anyone recall reading on this site that someone was repopping the RARE passengerside exhaust manifold with the heat tube for a 1959 dodge Super d500? I remember reading about it here. I searched high and low for the article and could not find it yet . | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | http://www.forwardlook.net/forums/forums/thread-view.asp?tid=52108&... | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | I thought someone had these manifolds in production . maybe over seas ? where are all these cloned super d500's and adventurer's getting these manifolds? | ||
d500dodge59 |
Veteran Posts: 245 | the man that maked them made 10 and needed 2 and i bougt the other 8 | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | ok Jan . any more left for sale ? | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | Wasn't that same exhaust manifold used from 1958-61 ? with the 1958 361 , 59 383 , 60 383 , 61 413 . | ||
NicksGarage |
Expert Posts: 1223 Location: Ramona, CA | dodge59 - 2020-06-06 9:09 AM Wasn't that same exhaust manifold used from 1958-61 ? with the 1958 361 , 59 383 , 60 383 , 61 413 . '60 switched to the ram induction setup and have their own one-year only manifold. '61 lost the generator mount so it is 1961 only. | ||
58coupe |
Expert Posts: 1739 Location: Alaska | Don't forget the 58 Fury 350 also used it. | ||
d500dodge59 |
Veteran Posts: 245 | send your email and i will send you pictures of the manifold janfridberg@hotmail.com | ||
1960-FURY |
Veteran Posts: 257 | Looked for years no luck and just made one , used a old 392 Hemi piece and drilled the hole and had welded on. (IMG_9110.JPG) (IMG_9114.JPG) Attachments ---------------- IMG_9110.JPG (147KB - 210 downloads) IMG_9114.JPG (141KB - 198 downloads) | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | question....... I read somewhere that the tube that runs up to the choke is not under any exhaust pressure flow , there's approx 4-5" tube and that is inserted into the manifold off that nipple . Is that correct ? 1954 hemi had the manifold heat tube for the choke also. | ||
Expert 5K+ Posts: 9854 Location: Lower Mainland BC | dodge59 - 2020-06-08 8:00 AM question....... I read somewhere that the tube that runs up to the choke is not under any exhaust pressure flow , there's approx 4-5" tube and that is inserted into the manifold off that nipple . Is that correct ? 1954 hemi had the manifold heat tube for the choke also. Here is an example of a 55 Dodge hemi with an insulated (covered) metal tube from the nipple on the passenger side exhaust manifold to the choke. No flow per se but heat. But first, here is a 59 D500 showing the same type of choke heat tube Edited by 56D500boy 2020-06-08 1:11 PM (NicelyDetailedEarly55_270HemiWithFactoryEmbossedValveCoversThatHaveBeenPainted.jpg) Attachments ---------------- NicelyDetailedEarly55_270HemiWithFactoryEmbossedValveCoversThatHaveBeenPainted.jpg (136KB - 217 downloads) | ||
d500dodge59 |
Veteran Posts: 245 | The tube goes rigth thrue the manifold and get hot and that makes the air to rush to the choke | ||
1960-FURY |
Veteran Posts: 257 | That is what I am seeing. More pictures. (s-l1600.jpg) (IMG_9090.JPG) Attachments ---------------- s-l1600.jpg (286KB - 202 downloads) IMG_9090.JPG (80KB - 209 downloads) | ||
1960-FURY |
Veteran Posts: 257 | Before picture (IMG_9088.JPG) Attachments ---------------- IMG_9088.JPG (103KB - 209 downloads) | ||
Expert 5K+ Posts: 9854 Location: Lower Mainland BC | d500dodge59 - 2020-06-08 10:15 AM The tube goes right thru the manifold and get hot and that makes the air to rush to the choke I am not sure about the "rushing" to the choke part but I will agree about how the tube works inside the manifold, i.e. gets hot: (56DodgePolyExhaustManifoldShowingChokeHeatTubeOnOutside.jpg) (56DodgePolyExhaustManifoldShowingChokeHeatTubeOnInside.jpg) Attachments ---------------- 56DodgePolyExhaustManifoldShowingChokeHeatTubeOnOutside.jpg (202KB - 215 downloads) 56DodgePolyExhaustManifoldShowingChokeHeatTubeOnInside.jpg (187KB - 211 downloads) | ||
d500dodge59 |
Veteran Posts: 245 | i talk abouth the 58-59 manifold that is what the question started abouth | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | from what i summized , the old thread was deleted as infighting had occurred during its length with some i remember quite clearly . it was mostly about them being produced lawfully/unlawfully and some not being grateful that someone took it upon them self to have them reproduced . some even left the forum because of it --------------------------------------------later | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | wow ! That's why I couldn't find that topic about that manifold. one more thing to add is behind the round cover on the carb choke , there is a tiny hole that goes into the carb body and I think it has some suction on it maybe to draw some heat up thru the tube into the choke . | ||
d500dodge59 |
Veteran Posts: 245 | if you need one let me know | ||
