under hood/deck paint finish
rockerarm
Posted 2020-08-17 11:21 AM (#602161)
Subject: under hood/deck paint finish
5001001001002525
I have seen forward look era cars with a gray primer/sealer finish under the hood and in the trunk area regardless of the exterior color. (My 58 Savoy was like that). Also some with body color.
What would be considered correct for a 61 Fury with sport tone paint?
And, is green the correct color for the hood hinge springs?
Thanks guys
Will.
Fireflite56
Posted 2020-08-17 2:27 PM (#602166 - in reply to #602161)
Subject: Re: under hood/deck paint finish
10010010025
Hopefully someone with a '61 Plymouth can chime in, but I know on the '56 DeSotos the production plant was a factor that determined the color. Detroit cars had body-colored trunk underside and gray inner fenders, Los Angeles cars were dark gray trunk undersides regardless of body color with black inner front fenders. Ideally you can find a survivor '61 Plymouth that was built at the same plant as yours to compare.
Apollo 61
Posted 2020-08-17 10:21 PM (#602203 - in reply to #602161)
5001001002525
I have (8) 61 plys. All the hood hinges are exterior body color. Any that have any paint on trunk floor left are body color.
Bottom side of hood are body colors.
The only variant is 2 of them have black inner fenders with black firewalls with a different exterior paint.
I was told that those were built in different plants
rockerarm
Posted 2020-08-17 10:55 PM (#602205 - in reply to #602203)
5001001001002525
Thanks. My hood hinges are also body color, but... the hood springs on two cars I have are a dark green.
