| Has anyone else bought one of these distributors for their plymouth? I really need to know what wires go where. every piece of my wiring harness was gone when I started building this car and the distributor didn't come with any wiring instructions. I have a red and black wire coming out of the distributor and that's all. Any and all help is greatly appreciated. I'm finally gonna get to hear this car run after 2 years of work. |
Location: So. Cal | I haven't used it, but I can surmise what a red and black wire would go to. Red wire to positive side of the coil. Black wire to negative side of the coil. |
| should post a pic at least? or the link |
Like this one?
https://www.ebay.ca/itm/HEI-Distributor-Spark-Plug-For-Mopar-Chrysle...
Location: Finland | I bought one of these for my 361 Desoto. Plays beautifully so far and isn`t too ugly , quite small.
https://www.ebay.com/itm/322548203639?ul_noapp=true |
| https://www.ebay.com/itm/Ready-To-Run-Electronic-Distributor-HEI-SB-...
-360/202262156400?hash=item2f17c39470:g:~8cAAOSwLopaqrYN
| The one above is what I bought,. I have a blue wire from the ignition switch and that's all I have, no resistor or anything else. So does the red go to positive side of coil and black to the negative side of the coil? Where do I attach the hot wire from the key switch? Thanks again for all the help. |
Location: So. Cal | Yes, the hot wire from the key goes to the positive side of the coil too. |
| Thanks powerflite! I will get it wires and hope it fires! |
Location: Massachusetts | Willard, how did this work for you?
I have a '58 Plymouth and I am pretty sure the stock distributor is worn out. Starts fine, idles fine, accelerates fine, doesn't run well above idle at load. Did you just wire the distributor to the coil, no ballast resistor? Did it work OK?
Thanks! |
