best way to remove overspray from weatherstripping?
jerrybev
Posted 2020-10-01 6:59 PM (#603849)
Subject: best way to remove overspray from weatherstripping?
500100252525
Would appreciate tips on best way to remove paint overspray from window weather stripping. It is 3 years old.
thank you for your time.
jerry whitfield
57plymouth
Posted 2020-10-01 7:21 PM (#603851 - in reply to #603849)
Subject: Re: best way to remove overspray from weatherstripping?
20001000500252525
I would say acetone, but it may hurt the rubber. Maybe you can scrub it off with a scotchbrite pad. Probably going to have to live with it or replace it.
Posted 2020-10-01 9:31 PM (#603858 - in reply to #603849)
Subject: RE: best way to remove overspray from weatherstripping?
500020002000500100100100100
I've had good luck with removing overspray with Goof Off. Put a generous amount (damp but not dripping) on a paper towel/rag and gently rub the weatherstripping in the area of the over spray. But be careful. It will also remove paint if you are careless or apply too much.
Edited by 56D500boy 2020-10-01 9:32 PM
jerrybev
Posted 2020-10-01 10:01 PM (#603860 - in reply to #603858)
500100252525
hi
thank you ! What store(s) carry it in your area? and I'll check here.
sincerely
jerry whitfield
winston salem NC
Posted 2020-10-01 11:22 PM (#603865 - in reply to #603860)
jerrybev - 2020-10-01 7:01 PMWhat store(s) carry it in your area? and I'll check here.
The Home Depot at 1000 Hanes Mall Blvd in Winston Salem should have it, plus many hardware and/or paint stores.
https://www.homedepot.com/s/?search=Goof%20Off
