56 Dodge power steering
dels56
Posted 2020-10-04 7:23 PM (#603976)
Subject: 56 Dodge power steering
1001001002525
Hi guys n girls. I am considering converting to power steering on my 56 Dodge 315 poly but..
I will need a couple of Items to do the trick. So if anyone has an idea where I might find, please point me in the direction.
1) For the crankshaft. 2 groove. Early models of the 315 had a pulley but no balancer. I think the crank is the same diameter either way.
2) water pump pulley, 2 groove.
3) generator with p/s pump drive, 2 groove.
4) generator mounted p/s pump.
Del S
Posted 2020-10-04 8:51 PM (#603982 - in reply to #603976)
Subject: RE: 56 Dodge power steering
500020002000500100100100100
Del: You also need the complete coaxial steering column unless you have another way of doing it.
I would NOT go with the generator-driven PS pump (like I have).
I would go with a 1957 Dodge PS pump mounted low on the driver's (left) side of the engine. That way you could go with an alternator or an alternator made to look like a generator.
Just an opinion.
dels56
Posted 2020-10-04 11:51 PM (#603991 - in reply to #603976)
Subject: Re: 56 Dodge power steering
1001001002525
I know where there is a coaxial steering unit. If it is in good shape and rebuildable I could go o.e. just need to know if the rest is available. If no, then option 2.
Del
