Location: Wyoming | Does anyone know what floor and trunk pans will interchange? Is a two door hardtop the same as a four-door hardtop? Is a four-door sedan the same pan as a two door hardtop? |
Location: So. Cal | Trunk: '57-'59 Chrysler/DeSoto/Dodge/Plymouth all models, except wagons, all the same.
Front floor pans: ditto, and even the wagons are included.
Rear floor pans: Longer cars have larger floor pans, but the pattern is the same. 4dr hardtops have a large, thick plate attached between the doors that makes it difficult to use for replacement pans. 2dr Hardtops have a different rear cross-brace and there are other differences in bracing; too many to list. |
Location: Alaska | Nathan, don't forget that the front floor pans made for a power seat have a deeper pocket where the seat bolts in. |
