Location: Chestertown, NY ( near Lake George) | 59 Dodge 326 8 cylinder, need a fuel pump, any recommendations for source, thanks. |
Location: Lower Mainland BC | Shep - 2020-10-15 2:51 PM
For 1959, the 326 was the base Coronet V8. 1959 Coronet V8s were model MD2-L. On that basis, I think that the correct fuel pump is 1843 287 (See table below).
Searching for that as "1843287 1959 Dodge Fuel Pump" turns up a number of options for OE or replacement fuel pumps.
https://www.google.com/search?source=univ&tbm=isch&q=1843287+1959+Do...
Including:
https://www.moparmall.com/1752462-1752463-1843287-1843400-Fuel-Pump-...
https://www.hiltopautoparts.com/product/nos-mopar-fuel-pump-1957-63-...
Edited by 56D500boy 2020-10-15 7:41 PM
(1959DodgeCoronetFuelPumpPN1843287.jpg)
Attachments ---------------- 1959DodgeCoronetFuelPumpPN1843287.jpg (99KB - 186 downloads)
Location: Connecticut | Shep - 2020-10-15 5:51 PM 59 Dodge 326 8 cylinder, need a fuel pump, any recommendations for source, thanks. Do you have the original pump ? If so, rebuild it with a kit from Then and Now. When you use the original pump, you are assured of the correct pressure and volume. Aftermarket pumps may put out more than the recommended 5-7 pounds. Ron |
Location: Lower Mainland BC | ronbo97 - 2020-10-15 6:01 PM
Great suggestion Ron.
All the OP has to do is figure out which kit he needs:
https://www.then-now-auto.com/product-category/fuel-pump-kits/dodge-...
And then follow a video like this one:
https://www.youtube.com/watch?v=FqnVdL1oIpk
Good luck
Location: Chestertown, NY ( near Lake George) | Thanks guys, saw both of those on a search, thought I remembered an LA pump could be adapted by switching the arms. |
Location: Connecticut | If you have an original Carter pump, the four digit Carter number is on the edge. The 5th character is an 'S'. This is from my 55 Desoto. Ron
Edited by ronbo97 2020-10-16 11:32 AM
(Carter 2241S Fuel Pump Not Mine .jpg)
Attachments ---------------- Carter 2241S Fuel Pump Not Mine .jpg (160KB - 182 downloads)
