Mechanical Brake Lights Switch Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
dels56 |
Extreme Veteran Posts: 351 | I have done a disc brake conversion on my 56 Dodge Custom Royal and in doing so replaced the master cylinder with a dual reservoir unit. To use an original style hydraulic pressure switch meant I would have to T the switch inline someplace, which I did not want to do. As we all know those darn old pressure type switches were not that reliable. anyway, so lets do a mechanical. switch. I searched around and didn't like any of the automotive switches as they were all to large. I my quest I found a Honda Motorcycle brake light switch. Cheap and readily available (Amazon). Fabricating a switch mount bracket was a chore. I have sketches if anyone wants to do the same. Del S Edited by dels56 2021-03-05 12:41 PM (IMG_6937 (2).JPG) (IMG_6938 (2).JPG) (IMG_6939 (2).JPG) Attachments ---------------- IMG_6937 (2).JPG (204KB - 197 downloads) IMG_6938 (2).JPG (132KB - 201 downloads) IMG_6939 (2).JPG (139KB - 199 downloads) | ||
bbdakota |
Veteran Posts: 129 | I'd be interested in how it mounts if you get a chance to post some pictures. I also added a mechanical switch to my 56 royal when I put a dual master cylinder on but I'm not really happy with the way I mounted it. It'll be interesting to see what you came up with. | ||
GaryS |
Expert Posts: 1207 Location: Ponder, TX | FWIW, I had a mechanical switch and adjustable mounting bracket from a '79 Dodge Aspen that I parted out. I always look for factory Mopar parts whenever making mods in my FWL, so was pleased to find that it bolted onto my '56 Plymouth. | ||
Old Ray |
Extreme Veteran Posts: 507 Location: Invermere B.C. Canada - Rocky Mountains | Del, are you going to use a relay so that the switch only has to handle the low relay current ? | ||
dels56 |
Extreme Veteran Posts: 351 | Good day. 1) I will try to get a pic of the brake pedal mount but in the meantime, there is a lug on the left side of the mount up at steering column height. It has a 3/16 slotted hole which works for left right adjustment. 2) this was the only option I could come up with after many days of searching. 3) the switch is capable of handling the 12v on the motorcycle without a relay so it should be AOK. Darn technology. I don't know how to edit a photo and draw on it, so the pic is an attachment Dave F had sent me some pics of a brake pedal mount which I am using here due to the fact that I don't have one of my own to use. Save the fail as a PDF. Let me know if you can download the file. Del S Edited by dels56 2021-03-06 12:42 PM Attachments ---------------- Switch mount bracket.pptx (146KB - 197 downloads) | ||
Expert 5K+ Posts: 9664 Location: So. Cal | I usually just weld a small, simple plate with a threaded hole in it to mount the switch. Works well and is very easy to do, other than sticking your head up there to weld. (BrakeSwitch.jpg) Attachments ---------------- BrakeSwitch.jpg (31KB - 208 downloads) | ||
dels56 |
Extreme Veteran Posts: 351 | In the pic above from Expert 5k, you can see the tab with a hole in it to the left of his switch. One little #10 machine screw and no weld sparks to deal with. additionally I do do have welding equipment in my shop so this was my easiest route. Del S | ||
Expert 5K+ Posts: 9900 Location: Lower Mainland BC | dels56 - 2021-03-06 8:32 AM Good day. 1) I will try to get a pic of the brake pedal mount but in the meantime, there is a lug on the left side of the mount up at steering column height. It has a 3/16 slotted hole which works for left right adjustment. 2) this was the only option I could come up with after many days of searching. 3) the switch is capable of handling the 12v on the motorcycle without a relay so it should be AOK. Darn technology. I don't know how to edit a photo and draw on it, so the pic is an attachment Del S Del: I use PAINT (usually bundled with the computer when you buy a new one, at least a Desk Top running windows). It is pretty easy to use. Here is your diagram: (DelSsMechanicalBrakeLightSwitchMountingLocation.jpg) Attachments ---------------- DelSsMechanicalBrakeLightSwitchMountingLocation.jpg (27KB - 206 downloads) | ||
NC Adventurer |
Veteran Posts: 148 | Some months back there was a similar thread on the subject. Lancer Mike came up with a great adaptation of a mechanical switch that is easy, allows for future reversal to the original switch and causes no permanent changes to the vehicle. I did this conversion on my Adventurer and it was worked flawlessly. Here's a link to the thread: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=42562&... Best of luck in your work! | ||
