Wanted: Heater Fuel pump
Stroller
Posted 2018-10-07 1:13 PM (#571266)
Subject: Wanted: Heater Fuel pump
10010025
Hi there I am looking for the gas heater fuel pump to a 1956 Chrysler Imperial Mopar Instant Heat Conditionaire, made by Stewart Warner model 800. I need the fuel line from the engine fuel pump, the fuel pump mounted on the blower, the fuel line from the fuel pump to the heater and the tube from the blower to the the heater. Also am looking for the 2 air deflectors for the trunk mounted A/C unit. These thing mount on each side of the rear deck. The A/C unit is Mark IV from the John E. Mitchell company in Dallas, Tx.
I will try to ad pictures of what I am working with. If the rear deck picture shows, the 2 air deflectors go in the holes where the stuff animals are perched.
please email me if you have or know where I might find these things.
Thank you.
Posted 2018-10-07 3:40 PM (#571270 - in reply to #571266)
Subject: Re: Wanted: Heater Fuel pump
500050002000100100100
Very "cool" option, whish that you find all the parts. Be extremely careful with those old gas heaters - they had a flaming history.
I would test the heater but then not use it and perhaps even plug the fuel line.
Posted 2018-10-07 4:22 PM (#571276 - in reply to #571266)
Subject: RE: Wanted: Heater Fuel pump
50001000500100100
Because I view looking up parts as an interesting challenge and I have some resources that I kind of know my way around, I offer that the fuel pump that you seek is PN 1688 445. The diagrams and parts lists below back that up.
Doing a Google Search on "1688445 heater fuel pump" didn't turn up exactly that part but it did show up some modern day equivalents that would work for you:
https://www.google.com/search?client=firefox-b&ei=TmW6W-2wLYuE8AOwiq...
Specifically, the Webasto (a German company that makes gas and diesel auxiliary heaters) petrol (gasoline) heater in-line fuel pump available at places like Heatso.com
https://www.heatso.com/webasto-fuel-pump-12v-petrol/
The Model 800 parts diagram shows the fuel pump as Item 30. Item 30 in the Parts list leads to Section 1-48-962 and Section 1-49-962 yields the OE PN of 1688 445.
Edited by 56D500boy 2018-10-07 4:25 PM
(Model800GasHeaterPartsDiagram.jpg)
(Model800GasHeaterPartsListingFuelPumpNo30InSection148962.jpg)
(Model800GasHeaterPartsListingSection148962FuelPumpPN1688445.jpg)
Attachments Model800GasHeaterPartsDiagram.jpg (151KB - 206 downloads)
Attachments Model800GasHeaterPartsListingFuelPumpNo30InSection148962.jpg (210KB - 208 downloads)
Attachments Model800GasHeaterPartsListingSection148962FuelPumpPN1688445.jpg (238KB - 202 downloads)
Old Ray
Posted 2018-10-07 7:19 PM (#571295 - in reply to #571266)
10010010010025
I'm thinking KA-BOOM !!
........  those parts willl be hard to find,....... I'm not sure if this is any help,  but if you wanted to retrofit something, the early Volkswagen air cooled bug had a gas heater.
Posted 2018-10-07 7:33 PM (#571297 - in reply to #571295)
50001000500100100
Old Ray - 2018-10-07 7:19 PM
I'm thinking those parts willl be hard to find,....... I'm not sure if this is any help,  but if you wanted to retrofit something, the early Volkswagen air cooled bug had a gas heater.
Probably made by Webasto I know Webasto was still making them in the mid-90's for C4 Audi 100s and a6s (1992-97) in Europe.
Hence my fuel pump suggestion.
rebel
Posted 2018-10-08 4:58 PM (#571347 - in reply to #571297)
100100252525
Jerry,
See my reply to your post in the For Sale forums for my 56 New Yorker parts.
Bob
hemidenis
Posted 2018-10-08 7:59 PM (#571356 - in reply to #571266)
2000100050010010025
I'm sure I have a NOS pump somewhere in the house, when I was trying to restore one of theses units. Purchased on ebay, and I never saw one again.
hemidenis
Posted 2018-10-12 6:38 PM (#571581 - in reply to #571266)
2000100050010010025
Sorry for the delay, I found the pump in my NOS stash. but is for the other heater model.
Edited by hemidenis 2018-10-12 7:33 PM
Stroller
Posted 2018-11-03 2:52 PM (#572854 - in reply to #571266)
10010025
HemiD I sent you a pm regarding your fuel pump.
Stroller
Posted 2018-11-11 12:48 PM (#573324 - in reply to #571266)
10010025
Update after searching high and low for a number of years I finally have a fuel pump on the way. Broke the rules of a web site since it a lot like the FWL main forums it was on a VW site since some bugs use the Southwind. It is a tiny bit different, but has the top parts I need and it is new NOS pump. IF nothing else at least all the parts that the car was born with will be in it. Might still be friged depending on where it is, but with the hood up all will be complete. Thanks to all that view and replied.
hemidenis
Posted 2018-11-11 8:51 PM (#573345 - in reply to #571266)
2000100050010010025
Yes, your pump is different than the other model. Glad you found one replacement!
Stroller
Posted 2019-01-12 12:08 PM (#576653 - in reply to #571266)
10010025
Here's an update to my saga for my heater. I finally found a tube that will work for the the blower to the heater unit. It is from a shop vac. The bucket head shop vac home depot carries. Wiered size of 1 1/4 OD x 1 3/8 ID. Too cold to either paint the blower and heater unit or not let alone to hook everything up right now.
plyjordan1930
Posted 2019-06-29 5:53 PM (#584233 - in reply to #576653)
I to want to rebuild my 800 heater. any luck with getting yours to work?? I have a 1956 Imperial with the 800 heater. I am going through what I have(unit was in the trunk) they put in a hot water heater in the car but never made it work. Just wanted to know how it was going for you Stroller. Yes I am going to put the 800 heater back in the car.
Stroller
Posted 2020-10-03 11:05 AM (#603934 - in reply to #571266)
10010025
Ok this again an old post. My heater does not use the second fender mounted box. After getting the wires to right spot and making sure the fan can run the fuel pump from the blower and making sure what opens when it should and the box makes clicking sounds to check operation while engine off and oh yeah making sure the other blower on the fire wall works when it should, 5 blowers in all in s**t darn thing. Oh yeah getting the "spark plug to work". All I can say is someone should have been shot for coming up with this crazy nightmare system. But going to a water type system would have taken on an entirely new world of engineering nightmares as no where are there ports anywhere on the engine alone and nothing to do with the firewall, dash or figuring out how to put in another heater box for where one never was.
Well in a nut shell it works. But what I did was put in a fuel drain so old fuel is not sitting in the unused lines. This car is now 100% complete as it was born although working not everything is original.
I do not suggest this darn heater system to any nut looking to make one work. It is a nightmare plain and simple.
22mafeja
Posted 2020-11-20 1:57 AM (#605812 - in reply to #603934)
100100
Some pictures please! You have done a heroic effort...
