Parade Green 57 New Yorker Coupe Jump to page : 1 2 3 4 5 Now viewing page 2 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 9670 Location: So. Cal | Thanks James and Garrett. I don't usually dive headfirst into rust repair, but in this case, I had to. We decided not to travel this Thanksgiving so I should get a good block of time to work on it this weekend. I hope I get as much done as I envisioned in my head; which pretty much never happens. | ||
macedon |
Elite Veteran Posts: 963 Location: San Antonio, TX | Wow. Fantastic progress in such a short time. Congrats. You are welcome to stop by my shop anytime. | ||
Expert 5K+ Posts: 9670 Location: So. Cal | Thanks Dave, if I am ever in your part of Texas, I definitely will! I finished welding the inner qtr panel and painted it. I had to remove the undercoating on it first. I made it out of a door skin from a '63 Nova I had laying around. But I wish I would have put the undercoating on the other side of the panel. It was a real pain to get it off. I didn't want it on the inside for fear of it eventually coming off and clogging up the drain with bare metal underneath it. It looks like someone tried to lift the car by the rusted rocker and bent up all the inner metal on it. It took me quite a while, but I managed to unbend all the inner rocker and got it in the proper position again. The outer metal there was torn up & rusted so I tacked an entire new rocker over the top of it to give it strength and welded up a number of cracks & holes in the surrounding metal. After that was done, I got to install my sweet new qtr panel. It went on really easily, and the only issue with it was the metal stuck out a little too far near the wheel lip so I had to massage it into shape before I welded it in. I paint all the in-between sides before I weld them together, mark the locations for the spot welds, and lightly grind the paint off with a tiny cutter. THat way, I get paint all between the joints. I didn't finish welding it because I wanted to get to the frame swap ASAP. I will finish welding it and clean up the welds in the next week or so, but it was now strong enough to lift so I went ahead and did it. I was able to pull the old frame out tonight and stripped most of the stuff off of it in the dark. Tomorrow, I will get the new frame under there and cut up the old one. (57NY Left Rocker Cover.jpg) (57NY Left Rear Qtr Welded.jpg) (57NY Frame Extraction.jpg) Attachments ---------------- 57NY Left Rocker Cover.jpg (147KB - 492 downloads) 57NY Left Rear Qtr Welded.jpg (139KB - 495 downloads) 57NY Frame Extraction.jpg (155KB - 500 downloads) | ||
DejaVu |
Member Posts: 31 Location: South Australia | It is thoroughly impressive to see the pace with which you attack these repairs. I'd love to see timelapse video of your driveway over the last year or so! Keep up the great work! | ||
Expert 5K+ Posts: 9670 Location: So. Cal | Thanks Ian, having a block of time off work helps alot I decided to paint the rear axle housing before I button it up to the new frame so I didn't get to install it yesterday. The leaf springs are the originals to the new '57 Windsor frame that are in great shape. The New Yorker leafs went into the scrap bin. But I had to use all of the hardware from the New Yorker as I can't seem to find the hardware from the Windsor. I know it's somewhere in my garage! It's a lot of manual labor swapping suspension parts around. My muscles aren't real happy this morning. Looking at the T-bars yesterday, I noticed that the right side was visibly bent. The left is very slightly bent, but probably livable. Strange, because I would have expected it to be the other way around since the frame was cut on the left side. So it looks like I will be using the Windsor bars on the car, which have the same part numbers anyway. It seems this car had a hard life in its past. (57NY Frame Install.jpg) Attachments ---------------- 57NY Frame Install.jpg (177KB - 515 downloads) | ||
Expert 5K+ Posts: 9670 Location: So. Cal | I got the frame in last week, but I set the body down in the back on 2 boards lying across the hump. So the rear part of the body is resting on those instead of the frame and makes it sit higher in the back. But the front part is sitting on the frame mounts with the bolts loosely installed. I did this because I have 3 rear body mounts that need work. I think I am going to only fix the 2 most rear mounts right now and save the other 1 for later, just to be able to get the car put together more quickly. The first mount I am working on is a result of someone cutting the mount out of the body. I presume that this was a shortcut to not having to remove a rusted nut, but cutting it like that doesn't look easy to do, so I am at a loss to explain the reasoning behind it. I will have to make a new panel for it and weld it in place. Not easy to do, because it will likely have to be done upside down. I HATE upside down welding. I still have burn marks on my chest from the last time one of those lava balls found it's way into there. The other mount is rusted in that area and requires a patch. I also cleaned up & painted the front control arms on the car and re-installed them to the new frame. I was surprised to find out that I couldn't re-use the old hardware from the New Yorker because they used 1/2"-20 fine threaded bolts, and the '57 Windsor frame uses 1/2"-13 coarse threaded bolts. What the?! So I checked out all my other cars and found that all the earlier '57 vehicles used the fine threaded bolts, and all the really late '57 & '58 cars used the coarse thread. This '57 Windsor frame was from a really late production build. Luckily, I managed to find the old Windsor hardware to put it back together. Now I just need to find that alignment wedge for the steering box! Finally, it took me a while, but I got the trunk lid back on, and latched in place. I had to remove a broken bolt from it, make a tool to re-attach the trunk springs, and find my extra catch that was missing from the car. But it is done now and works well. That was the biggest priority I had because it's a pain to try and keep rain out of there with it off. (57NY Rear Body Mount Missing.jpg) (57NY Front Suspension.jpg) Attachments ---------------- 57NY Rear Body Mount Missing.jpg (174KB - 521 downloads) 57NY Front Suspension.jpg (198KB - 518 downloads) | ||
Expert 5K+ Posts: 9670 Location: So. Cal | I cleaned up the welds on the quarter panel repair and made a first pass at the hammer & dolly work to smooth it out. This is likely the easiest lower quarter repair job I have ever done. This hobby is a lot more fun when you have good replacement panels to work with. It needs just a little more hammer work to get it perfect, but is real close now. I also ground down the surface rust on the quarter along with some of the bondo that is there, sprayed it with a rust converter and painted it to preserve it better. Then I replaced the spear side trim with one that is 2" longer (the right length) so that it will reach all the way to the tail light properly. Not sure why that one is so short. It doesn't look to have been repaired or messed with so I don't know what happened with it. I also repaired the left rear body mount that someone had cut out. It came out much better than I expected. I could probably clean it up a little better if I had the body on a rotisserie, but it came out surprisingly well anyway. One down, 2 to go before I can finally set the body down. (57NY Qtr Finish.jpg) (57NY RearMount Weld Top.jpg) (57NY RearMount Weld.jpg) Attachments ---------------- 57NY Qtr Finish.jpg (114KB - 488 downloads) 57NY RearMount Weld Top.jpg (210KB - 531 downloads) 57NY RearMount Weld.jpg (169KB - 487 downloads) | ||
Expert 5K+ Posts: 5006 | heh been there, done exactly that same weld | ||
firedome |
Expert Posts: 3155 Location: NY & VT | Clearly this car went to the right home, great start! | ||
finsruskw |
Expert Posts: 2289 Location: Eastern Iowa | Do you have any of this to deal with?? (300C_floor_pan_002.jpg) (300C_floor_pan_008.jpg) Attachments ---------------- 300C_floor_pan_002.jpg (59KB - 489 downloads) 300C_floor_pan_008.jpg (49KB - 490 downloads) | ||
Expert 5K+ Posts: 9670 Location: So. Cal | Thanks Roger. Dave, yes, of course I do. Even my California cars with very little rust have that issue. Those were designed very poorly. If you are repairing them, make sure you paint them in between the parts before you weld them together. Once condensation or other moisture gets in there, it's pretty much game over if they are bare metal contact...and of course they are the lowest point in the car so that's where any water will naturally go. This is the second rear mount I am repairing. This one is much more involved, but I made a good start on it by making a repair panel for it from a '63 Nova door skin. It wasn't easy to make due to all of the compound curves on it and it isn't quite finished yet. I am going to cut the vertical bend very short so that it is barely above the bottom of it. Some of that edge needs a little more massaging as well to get it right. Once I cut the old one off, I can better see how it needs to be modified to get it right, and I will use it as a template to get the hole in the right spot too. (57NY Rusted Rt Rear Mount.jpg) (57NY Rt Body Mount Replacement.jpg) Attachments ---------------- 57NY Rusted Rt Rear Mount.jpg (122KB - 499 downloads) 57NY Rt Body Mount Replacement.jpg (170KB - 497 downloads) | ||
finsruskw |
Expert Posts: 2289 Location: Eastern Iowa | I made my pieces from scratch well. If you remove the original in one piece by cutting/drilling the spot welds ad can line it with something, Then fill the trough with plaster or cement. When it sets remove the casting and use it as a base form for making a template to lay thin cardboard over it. It will become obvious at this point where it needs to bend an lap back onto itself to make the tray. Mark the cardboard where the bends need to be, allowing 3/4" or so for the lap joints front and rear Cut out the cardboard to use as a paattern. You will find there is a slight difference between the lt and rt sides. Then lay the pattern on a piece of new sheet metal, trace and cut. I used a homade break for my press to do the bends, kind ofa PITA though, whatever you do. I cranked out 8 or 9 pairs of these and sold them years ago, some went clear to New Zeeland!! It was fun figuring it out,,,,,then…. and doing it! But now it would just be work....and I'm retred!! insert smiley face (here) I have a few more pic's somewhere I was lucky to have OEM NOS rockers to work with. You can see the rest of the sheet metal work on the car here http://www.chrysler300club.com/tech/schwandt/schwandt.html Edited by finsruskw 2018-12-18 8:29 AM | ||
Expert 5K+ Posts: 9670 Location: So. Cal | Nice job Dave. I hand made those things for my copper '57 Windsor as well. It wasn't very easy to do and I don't really want to do it again, but I need at least 2 more sets of them now. Jan in Sweden makes them, but it can be quite expensive to ship so I am not sure what I will do yet. I may just leave them alone! Heaven knows I've got plenty of other issues to deal with. I got the disc brakes installed on the car. The long bottom bolt was a huge headache on both sides. They were totally seized in the steering arms. I had to cut them into 4 pieces and heat the remainder of the bolts red hot to eventually get them out of there. I broke my only 1/2" drive 5/8 socket trying to turn them with a breaker bar so I need to head to the tool store today. But it's done so all is good. Just need to bend the lines & install the power brake pedal assembly since the car originally came with manual brakes. (57NY Disc Brakes.jpg) Attachments ---------------- 57NY Disc Brakes.jpg (149KB - 483 downloads) | ||
finsruskw |
Expert Posts: 2289 Location: Eastern Iowa | What are you gonna do for a MC? Was it all a bolt on deal? | ||
Expert 5K+ Posts: 9670 Location: So. Cal | Yes, a bolt-on from Scarebird. It requires 15" wheels. With power brakes, I like to run a remote-fill master. I can no longer purchase the master shown on my car in the picture, so I will try to use one from a 1990 Mitsubishi FUSO truck that has a 1.125" bore size. It's a 4-bolt master like the Chrysler units, but the mounting holes have to be moved outward a little to make it work. I'm not sure yet how it will turn out, but I'm sure I can get it to work. (57NY Firewall Closer.jpg) (dhb-m630742_hn_xl.jpg) Attachments ---------------- 57NY Firewall Closer.jpg (188KB - 487 downloads) dhb-m630742_hn_xl.jpg (126KB - 480 downloads) | ||
Expert 5K+ Posts: 9670 Location: So. Cal | I purchased these air cleaners for the car from Smitty. They look like a complete basket case, so they should fit right in with the general theme of this car. But I figure that I can cut the spot welds, cut an appropriate sized hole into a new lid and spot weld it back onto them. That's the plan anyway. (Sad Air Cleaners.jpg) Attachments ---------------- Sad Air Cleaners.jpg (250KB - 439 downloads) | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Looking Good Nathan | ||
Expert 5K+ Posts: 9670 Location: So. Cal | Thanks Billy. Hopefully this weather will let up a little so you can enjoy driving yours again. I wasn't planning to work on this today, but it was raining most of the day so I spent my time working inside the garage instead of doing what I had planned. These air cleaners were reaching out to me with their tetanus fingers so I decided to do something with them. I pulled two new lids from my attic and marked them to cut a proper hole into them. The originals have a 4.25" hole. Then I rather sloppily cut them out with a plasma cutter and cleaned up the cut to my mark with a tungsten-carbide bur on a die grinder. The center pad smokes forever when you do this, but the rain eventually put it out so I didn't have to mess with it. I also spent quite a bit of time to straighten one tube out as it had been bent up quite a bit. I had to use a long bent punch that I made for a different application; but that was able to reach down inside them and pop out all the problem areas. I made a new tab out of 1/8" plate to replace the missing one on it. I bent the radius on the bottom of it by separating my vise jaws to create a gap and hammering a rod onto the tab, into the gap. It worked out quite well. Rather than split all the spot welds for the flange that the lid welds to, I just cut a slot into it so that I could slip the lid over it. I'll weld up that slot before I spot weld them together....the problem is that I didn't own a spot welder and have never done it before. I didn't want to plug weld these so I went to Harbor Freight and bought a 240v version. I just need to practice with it and see how to do it before I try my hand with the real thing. Spot welding the tab may not work real well, so I may end up plug welding that one. We'll see. Edited by Powerflite 2019-03-02 10:52 PM (New Recruits.jpg) (Fire In The Hole.jpg) (Straight With New Tab.jpg) (Just Add Spots.jpg) Attachments ---------------- New Recruits.jpg (162KB - 459 downloads) Fire In The Hole.jpg (193KB - 443 downloads) Straight With New Tab.jpg (92KB - 467 downloads) Just Add Spots.jpg (114KB - 452 downloads) | ||
Expert 5K+ Posts: 9670 Location: So. Cal | The rust holes in the left wheel lip started to bug me every time I walked past them. So I decided to fix them so I don't have to look at them any longer. I fixed most of the inner wheel house issues, the top of the wheel lip and the upper front section of the lower lip. I still have to do the lower section along most of it, but that part is less visible. My subconscious feels much better now. We are expecting more rain so I had to epoxy prime it right away. There is a little dip in the lip right where the new quarter was welded on, so I need to weld that back in as well. Sometimes I don't see all the issues until it is all one uniform color. Edited by Powerflite 2019-03-19 12:48 PM (57NY Left Wheel Lip Top Repaired.jpg) Attachments ---------------- 57NY Left Wheel Lip Top Repaired.jpg (99KB - 450 downloads) | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | Some great progress! Those air cleaners were a real mess, wow... | ||
Expert 5K+ Posts: 9670 Location: So. Cal | Thanks, they were worse than they look. I spent a couple of hours straightening them after separating the junk lids from them. | ||
Expert 5K+ Posts: 9670 Location: So. Cal | In order to replace the rear body mount on the right side, I needed to replace the trunk drop down first since they get welded together. And to do that, I needed to get the outer quarter squared away as well. So I cut the replacement quarter to fit up to the old quarter and get it ready to weld in the right spot before I replace the drop down. This way I can ensure that I get it in the right location when I put it back together. I also measured out the height and compared it with my other vehicles as it is easy to get it 1/4" off. Now I will bend up a new trunk drop down and weld that in place after I check the fit with the replacement quarter. I'm all out of Nova door skins so I'll cut up a '57 Windsor sedan rear door to use for it. (57NY RtRr Quarter Placement.jpg) Attachments ---------------- 57NY RtRr Quarter Placement.jpg (163KB - 473 downloads) | ||
Expert 5K+ Posts: 9670 Location: So. Cal | The drop down is out. Needs just a little patching and cleaning up before a new panel can go in. I am keeping the old one around to use as a pattern for the new panel. (57NY RR Drop Down Removed.jpg) (57NY Rubbish.jpg) Attachments ---------------- 57NY RR Drop Down Removed.jpg (169KB - 443 downloads) 57NY Rubbish.jpg (287KB - 483 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Good work, keep it up and you'll soon cruise down the lane | ||
Expert 5K+ Posts: 9670 Location: So. Cal | Thanks Sven. This one is very needy, but I do enjoy working on it. I finished fabricating the trunk drop-down for it. I had a couple of false starts with incorrect dimensions, but once I got it figured out, it came together pretty well. I just need to cut the holes into it so I can plug weld it back into the trunk pan. The white residue that you see is what remains of the thick bondo slathered on the Windsor door that I cut this panel from. I left the bottom flange extra wide so I can trim it to size once I get the outer panel welded to it. It would have been really nice to be able to purchase this part, but the crap that is available here is completely worthless. Comparing the two photos, the top portion doesn't look to be wide enough and it doesn't have the required taper in its width that the original has either. The angle & length of the front up-flange is all wrong, and doesn't include the tab for mounting the section to the wheelhouse. Who knows what they had in mind at the back-end of it. They included some artistic flair that has nothing to do with what is needed. And the bottom flange edge isn't straight. It has some weird kink in it for some stupid reason. He also bent the flange that welds to the trunk pan in the wrong direction! It was supposed to bend up, not down. What the heck?? Can we get someone who isn't completely blind and stupid to make parts for us instead? Until then, all we have is Dopey's workshop building us parts. If Real Steel Replacements were to make some good trunk drop downs, that would be a nice change, but I don't want to be the first one to try it out from him, so I made it myself. Edited by Powerflite 2019-04-06 11:19 PM (57NY Rt Trunk DropDown.jpg) (Crap.jpg) Attachments ---------------- 57NY Rt Trunk DropDown.jpg (174KB - 433 downloads) Crap.jpg (57KB - 429 downloads) | ||
Expert 5K+ Posts: 9670 Location: So. Cal | I made up a template in Solidworks in case I need to make another one of these for a different car in the future. Starting with a good template makes the work go much easier. This is for the right side. In theory, you could just bend it the opposite way to get the left side, but the left has a rectangular hump in the middle of it for the spare tire to rest on, so it is a little different. The rear part of it needs to be split at the top of the bend to go upward a bit (see the part that I made above). Afterward, you need to add material to match up to it from the side as well. The numbers seem more accurate than they really are. They didn't come out as round numbers just because Solidworks takes into account the bend radius that I used, which was set at 0.1". But these numbers are just pretty close so you should check everything first before you make your bends. I hope it helps someone. Edited by Powerflite 2019-04-09 1:20 AM (Trunk Dropdown Model.jpg) (Trunk Dropdown Drawing.jpg) Attachments ---------------- Trunk Dropdown Model.jpg (32KB - 438 downloads) Trunk Dropdown Drawing.jpg (70KB - 433 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Thanks' a lot Nathan, this will help many guys to make those repair parts - really nice to have it made in Solidworks as well. Hypothetically, with that file and a hard core sheetmetal company it would be possible to get those panels cut and bent directly from file. | ||
miquelonbrad |
Expert Posts: 1737 Location: Hay Lakes, Alberta, Canada | Nice job Nathan!!! | ||
Expert 5K+ Posts: 9670 Location: So. Cal | Thanks, I hope this pattern will help someone out. I traveled to my in-laws over the weekend so I didn't get to work on my cars, but I stopped by my wife's great-uncle's place on the way. He has a large shop with a mill and he invited me to use it when I needed to. So I brought a bunch of Isuzu master cylinders with me and modified the mounts to work with the Chrysler 4-bolt pattern. I should have brought my own end mills as his were well-used high speed steel and I prefer to use tungsten-carbide, but I got it done. 5/16" or 11/32" would have been nice, but I settled for a 3/8" size that gave me a little more clearance than needed. My hands were very black with iron dust by the time I got done. Looks like it is going to work out well on there. (Modified Master.jpg) (Isuzu Master Mods.jpg) Attachments ---------------- Modified Master.jpg (140KB - 431 downloads) Isuzu Master Mods.jpg (47KB - 421 downloads) | ||
Expert 5K+ Posts: 9670 Location: So. Cal | I welded the trunk drop down in, removed the rusty section of body mount and welded a patch into the rear of the trunk floor. I still need to clean up all the welds, I just ran out of time yesterday. The old body mount is really rusty, so it doesn't give me much to go on as far as using it as a pattern for the new one, but I was able to use it to get the new hole drilled in the right spot. I've decided to cut the section only on the bottom to preserve the original edge, but it means welding the whole thing upside down, which I hate doing. But I think it should be worth it (hopefully). I need to repair a section of the rear vertical part first, so that's next, after the clean up is done on these welds. (57NY Right Side Drop.jpg) (57NY Right Trunk Drop.jpg) (Rusty Rear Mount.jpg) Attachments ---------------- 57NY Right Side Drop.jpg (92KB - 416 downloads) 57NY Right Trunk Drop.jpg (133KB - 425 downloads) Rusty Rear Mount.jpg (126KB - 422 downloads) | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | You are doing a GREAT job on this car, Nathan. It's a ton of work to bring one back, but I think this is a worthy cause. I'd really like to get the two twins together someday! | ||
Expert 5K+ Posts: 5006 | I feel your pain, did you make your lower quarter panels? I have some coming from real steel, I sent him my original Schotts so he could copy. | ||
Expert 5K+ Posts: 9670 Location: So. Cal | Thanks Danny, I appreciated the encouragement! I would like to get them together someday too, if for nothing else, but to see your great car in person. Mike, I made the inner trunk drop downs, but I didn't make the outer quarter panels. That is beyond my skill level to do it properly. I purchased those from Lennart in Sweden. Well worth the cost. I probably should have purchased more of them because it's the shipping that hurts. The panel looks better with the welds cleaned up and in a more uniform color. Once the primer drys, I will try to straighten out the crease & panel better before I weld the new body mount underneath it. (57NY Trunk Repairs.jpg) Attachments ---------------- 57NY Trunk Repairs.jpg (125KB - 414 downloads) | ||
The Adventurer |
Elite Veteran,, James Passed away March 2021, He will be Missed Posts: 1028 Location: Melbourne, Australia | Good work Nathan , i done these a few times now and know how painful it is making the parts and then welding that terrible japanese spring steel these cars had to new steel is a pain . The top shape on the on that drop panel is a starange one to make as it geoes 2 ways and a paper pattern doesnt help much . Unless you make one you wont get it ! | ||
Expert 5K+ Posts: 9670 Location: So. Cal | True, it is impossible for a home guy to complete the back portion without welding a separate piece into it. I decided to just add that separate piece after the drop down was welded to the body, but I should have did it separately so that it would be easier to clean up afterward. But it isn't impossible to do it on the car, just harder. | ||
The Adventurer |
Elite Veteran,, James Passed away March 2021, He will be Missed Posts: 1028 Location: Melbourne, Australia | Yes totally agree. I bought a cheapy swaging machine and made a complete half trunk floor in a few hours for my 59 Fireflite coupe . So as you say these things are possible at home but the trunk floor in its entirity is quite a pain to do , especially if that back lower panel is gone . | ||
Expert 5K+ Posts: 9670 Location: So. Cal | I tack welded in the vertical section of the body mount that was rusted out. I bent a flange on the panel before I cut most of it off. That allowed me to still be able to give it the "S" bend shape that it required, and yet have a bend on the end of it that matched the edge of the rest of the panel. I'll have plenty of time to finish welding it tomorrow, but it's gonna be real fun cleaning up those welds in that pocket up there. But I do have a plan to get it done. (57NY Vertical Body Mount.jpg) Attachments ---------------- 57NY Vertical Body Mount.jpg (128KB - 413 downloads) | ||
The Adventurer |
Elite Veteran,, James Passed away March 2021, He will be Missed Posts: 1028 Location: Melbourne, Australia | These type of sanders are the best for welds in tight spots (maybe buy a better one , but you get the idea) , They nip down welds quicker and better than a normal grinder with flap disk . https://www.ebay.com/itm/3-8-Air-Belt-Sander-Machine-Sanding-Grindin... You need a good compressor to keep the air to these air tools to keep the speed up . But they are safe in tight spots also ,so you wont have issue with hurting yourself unlike you can with a regular grinder | ||
Expert 5K+ Posts: 9670 Location: So. Cal | I've never thought of using something like that. Thanks for the tip! I'll give it a try. | ||
The Adventurer |
Elite Veteran,, James Passed away March 2021, He will be Missed Posts: 1028 Location: Melbourne, Australia | Happy to help Nathan ! | ||
Expert 5K+ Posts: 9670 Location: So. Cal | I was surprised to find that the parade green color on the inside of the windshield trim didn't match the brighter color underneath the outer trim. Instead it matches the more oxidized color. But I think that the brighter color was the original for the outside at least, and that's what I am going to paint it. The bright color will look better with the white highlights anyway. The roof of my 4dr parts car (parade green with white roof/sweep) also shows this brighter color under it's trim. Getting those trim clips off was not fun, but much easier with a hot wrench handy. I am going to replace that flat plate clip with one made from stainless, and all the screws here will be stainless too. I don't like outer screws rusting away like this. Edited by Powerflite 2019-05-25 11:41 AM (Parade Green Color Differences.jpg) (57NY Roof Trim Clips.jpg) Attachments ---------------- Parade Green Color Differences.jpg (89KB - 384 downloads) 57NY Roof Trim Clips.jpg (137KB - 400 downloads) | ||
Expert 5K+ Posts: 9670 Location: So. Cal | The trunk lid of this 2dr car was replaced at some point, but inside the trunk shows how it was painted. It looks like it was originally gray inside, like my other car built in LA; but unlike that one, this one has a lot of body color over the top of the gray. Also the trunk lid of my Detroit-made 4dr parts car is a nice uniform shade of body color (parade green); whereas my LA built New Yorker just had a gray inner trunk lid. (57NY Detroit Trunk Color.jpg) (57NY Detroit Trunk Floor Color.jpg) (57NY Detroit Trunk Lid Color.jpg) Attachments ---------------- 57NY Detroit Trunk Color.jpg (149KB - 404 downloads) 57NY Detroit Trunk Floor Color.jpg (180KB - 389 downloads) 57NY Detroit Trunk Lid Color.jpg (130KB - 421 downloads) | ||
The Adventurer |
Elite Veteran,, James Passed away March 2021, He will be Missed Posts: 1028 Location: Melbourne, Australia | Interior colours were always a different colour code Nathan and have flatting base generally . or off the gun finish . Also be careful with colours inside trunk lids and places you would think that have untouched paint as they've never seen the sun , as the heat still transfers through for years and can lighten the pigments and also especially with metallic greens and some other colours if they got a one shot bit of colour in one of these non important areas , the colour shade might be out as it may need multiple coats to bring out its true colour plus clear . I would get it mixed up to the original formula which is no problem as you are in the US . | ||
Expert 5K+ Posts: 9670 Location: So. Cal | This tire has no weight on it as you can see the jack stand under there. This is the 2nd newer tire to blow up on me just from sitting in the sun. The first was a Goodyear brand and this one is a Summit brand (not affiliated with Summit Racing). I hope these crap formulated rubber was something they no longer use because this is ridiculous. (2nd Blowout.jpg) Attachments ---------------- 2nd Blowout.jpg (137KB - 416 downloads) | ||
KcImperial |
Expert Posts: 2490 Location: Kansas City, KS | You're not the only one. I have that often with tires that sit on concrete for an extended period and then are lifted up. I'm speculating it has something to do with weight being isolated to a small area of the tire I'm sure there's some engineers here that can explain it better. This one sat for almost 10 years no problem then blew out less than an hour after jacking it up I was underneath changing a u-joint at the time. Had to change pants afterwards (tire2.jpg) Attachments ---------------- tire2.jpg (76KB - 400 downloads) | ||
Expert 5K+ Posts: 9670 Location: So. Cal | I finished the right rear body mount repair today. I'm pleased with how it turned out and it is now painted all inside that trunk seam as far as I could get it while the panel was removed. So hopefully it won't rust there as easily now. I got distracted by other projects and haven't had a lot of time to finish this, but I'm glad to be moving on to another part of the car now. Cleaning up the welds in tight spots was a lot easier with that new sander. Thanks for the tip James. Next I will be repairing the two middle body mounts. Hopefully it won't take as long as the rears. My immediate goal here is to be able to get the body back on the frame and mount the steering box so I can move the car when I need to. I will have to pause on it again though to rebuild the front end on my '58 Coronet since the control arm bushings self destructed... Edited by Powerflite 2019-07-07 1:42 AM (57NY RR Body Mount Repaired.jpg) (57NY RR Body Mount Repaired & Primed.jpg) Attachments ---------------- 57NY RR Body Mount Repaired.jpg (130KB - 388 downloads) 57NY RR Body Mount Repaired & Primed.jpg (123KB - 387 downloads) | ||
Expert 5K+ Posts: 9670 Location: So. Cal | I welded up the mid body mount on the right side of the car yesterday. Most of it was in pretty good shape. Just the end was rusted out so I decided to patch it instead of trying to replace it. The guy in Finland makes new floor supports, but only the front and rear supports. These mid mounts are a little different and he doesn't make a direct replacement for them. Unfortunately, on a '57-'58, these mid mounts are usually in the worst shape of all of them. I bent the end of it down to match well with the vertical part of it and I was able to weld most of that part from above. But the rest had to be done upside down. I probably won't be able to clean up the welds as much as I would like to because the frame is now in the way, but I'll do my best with it. (Rust Right Mid Body Mount.jpg) (Welded Right Mid Body Mount.jpg) Attachments ---------------- Rust Right Mid Body Mount.jpg (168KB - 415 downloads) Welded Right Mid Body Mount.jpg (146KB - 384 downloads) | ||
Expert 5K+ Posts: 5006 | eh that got it... my braces were good, i was shocked, had to clean them up and rustproof though. that was a pita | ||
Expert 5K+ Posts: 9670 Location: So. Cal | Everything that I have to do upside down on the floors of these cars is a real pain, but without the space for a rotisserie, I gotta live with it. I got the welds cleaned up as well as I am going to do. It isn't perfect, but a future owner can put the body on a rotisserie to do a better job with it many years down the road if they so desire. But I think it turned out quite well for something that no one is really going to see. Not sure why I put the effort into it really, but couldn't just leave it like it was. It's amazing how much this fix strengthened the floors above. Much more solid now. That was the real motivation in doing it. Only 2 more to go on the left side of the car and I will be able to set the body down on the frame for good - while I own it at least. Edited by Powerflite 2019-08-07 12:52 AM (57NY Mid Body Mount.jpg) Attachments ---------------- 57NY Mid Body Mount.jpg (164KB - 383 downloads) | ||
Expert 5K+ Posts: 7400 Location: northern germany | Love your work as you obviously want to protect/preserve whats left to keep it as original as possible. I too use old steel from junk fenders, etc. Because 1rst, it is free, 2nd, because it is the correct gauge and very easy to work with, 3rd, I hate to throw things away that once required energy to fabricate and 4th, I love the idea that the metal that goes into my project is "50s steel" too. Edited by 1960fury 2019-08-13 6:52 AM | ||
