1957 DeSoto Power Steering pump Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
JGC403 |
Regular Posts: 57 Location: GREENEVILLE, TN | Can anyone tell me what pump I have? The car has been sitting for around 10 years without being run. Power steering reservoir is just about empty and the bottom of the pump is wet with fluid. Does anyone rebuild these? Edited by JGC403 2019-03-16 6:21 PM (DeSoto Power Steering Pump.jpg) Attachments ---------------- DeSoto Power Steering Pump.jpg (49KB - 337 downloads) | ||
FINS! |
Elite Veteran Posts: 943 | Looks like it might be the Vickers type. I ordered a rebuilt one for my '57 Dodge through Rock Auto. They are rebuilt by Lares Corp. | ||
ToMopar |
Elite Veteran Posts: 1159 Location: D-70199 Heslach | You have pump #1826158 (1756.jpg) (1759y.jpg) (1760n.jpg) Attachments ---------------- 1756.jpg (130KB - 322 downloads) 1759y.jpg (154KB - 305 downloads) 1760n.jpg (145KB - 308 downloads) | ||
Icy '58 |
Member Posts: 42 Location: LuleƄ, Sweden | When a pump like this getting bad pressure on idle when the engine is hot. No leakage. What is it that is worn? the rebuild kits seem only to have gaskets. My steering fluid was very bad and I am changeing it now. But could it bee anything more in the pump that is bad? | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | ToMopar - 2019-04-14 5:45 AM You have pump #1826158 Thanks for posting that number. I was able to chase it in the 55-58 Mopar Parts Catalogue pdf and then find the 1672 697 Eaton pump that is on my 56 Dodge (driven by the back-side of the generator). Hope I don't derail the thread. (I've posted diagrams for both my 1672 697 Eaton pump and the 1826 158 Vickers so not to mess up the thread too much). Edited by 56D500boy 2019-07-02 8:48 PM (55-58PowerSteeringPumpPNs.jpg) (1826158PowerSteeringPumpExplodedPartsDiagram.jpg) (1672697PowerSteeringPumpExplodedPartsDiagram.jpg) Attachments ---------------- 55-58PowerSteeringPumpPNs.jpg (208KB - 292 downloads) 1826158PowerSteeringPumpExplodedPartsDiagram.jpg (146KB - 291 downloads) 1672697PowerSteeringPumpExplodedPartsDiagram.jpg (159KB - 307 downloads) | ||
Icy '58 |
Member Posts: 42 Location: LuleƄ, Sweden | Icy '58 - 2019-07-02 11:43 PM When a pump like this getting bad pressure on idle when the engine is hot. No leakage. What is it that is worn? the rebuild kits seem only to have gaskets. My steering fluid was very bad and I am changeing it now. But could it bee anything more in the pump that is bad? No difference with new fluid. Still bad pressure in idle when turning the wheel and hot engine. Could it be better if I buy a kit for the pump and change everything included? | ||
22mafeja |
Elite Veteran Posts: 655 Location: Finland | Are you sure the pump is the issue? I would check the pressure by just loosening the return hose or the valve bolts. It should of course leak heavily at once. If it does leak out you have to put in a o-ring and piston ring kit in the gear unit. These kits you can probably get from any us car parts dealer in Sweden or from ebay. | ||
