1956 Plymouth
Muffin1
Posted 2019-05-28 10:31 AM (#582607)
Subject: 1956 Plymouth
100100
I have a 56 Ply with a 277 engine do they make a conversion kit for the distributor
If so where can I get one
Thanks Alex
ABloch
Posted 2019-05-28 10:41 AM (#582610 - in reply to #582607)
Subject: Re: 1956 Plymouth
1000100100100
Two options, AFAIK. One, find yourself a dual point distributor and swap out the guts with a Pertronix ignition module.
Second, get yourself an all in one electronic distributor. I don't have the number in front of me right now, but I'll get back to you.
I just pulled one out of my 303 and it's sitting on the shelf.
ABloch
Posted 2019-05-28 10:59 AM (#582612 - in reply to #582607)
1000100100100
https://www.ebay.com/itm/Dodge-Chrysler-Plymouth-318-340-360-LA-V8-R...
Cap/191448261750?hash=item2c9334a476:g:tpoAAOSwiCRUjKqw
Muffin1
Posted 2019-06-05 5:49 PM (#582978 - in reply to #582607)
100100
A Bloc Thanks for the info I contacted the E bay seller that you gave me { see above ]
they do not have a distributor for my 56 ply 277 V8 engine
and other help.
Posted 2019-06-05 6:28 PM (#582984 - in reply to #582607)
500010005002525
The 277 engine uses the same distributor as the later 318 and 340 motors. They are a direct bolt-in.
Edited by Powerflite 2019-06-05 6:29 PM
Muffin1
Posted 2019-06-05 8:39 PM (#582989 - in reply to #582607)
100100
Thanks Powerflite I will talk with them again and see what they say
ABloch
Posted 2019-06-05 11:37 PM (#582994 - in reply to #582607)
1000100100100
Talk to someone else because that is the distributor you want.
Muffin1
Posted 2019-06-11 7:09 PM (#583305 - in reply to #582607)
100100
Thank you Powewflite and ABoch distributor came to day the one you said. Fit in with just a little
filing on the part that goes into the oil pump gear.
My question is do I have to use the coil resistor with this distributor
Posted 2019-06-11 7:21 PM (#583307 - in reply to #582607)
500010005002525
It says HEI. HEI systems don't need the ballast. But you would need one if you use an old style coil with less than 1.5 ohm primary resistance. Your stock coil would need the ballast as they are typically .5 ohms.
Muffin1
Posted 2019-06-11 10:31 PM (#583320 - in reply to #582607)
100100
Thanks Powerflite I will see if this bad boy starts tomorrow
More to follow
Muffin1
Posted 2019-06-13 4:33 PM (#583387 - in reply to #582607)
100100
Gentleman
Should I use a HEI type coil instead of the old style ??
Posted 2019-06-13 4:40 PM (#583388 - in reply to #582607)
500010005002525
It's up to you. It will work with the old style coil if you want to use it, but the HEI will give you more spark power.
Edited by Powerflite 2019-06-13 4:41 PM
71charger_fan
Posted 2019-08-28 9:41 AM (#586694 - in reply to #582607)
500100
You can also use the late 80s to mid-90s Ford coil (Standard FD478) which is essentially the same as the HEI coil but with a different plug (Standard HP4370).
