1956 Plymouth
Muffin1
Posted 2019-06-01 10:46 AM (#582793)
Subject: 1956 Plymouth
10010025
I have a 56 Ply with a 277 engine in it I want to change the automatic transmission to a stick
shift on the column . My understanding is there is one bell housing to fit the 277 and that
is only a 1956 277 no other years same as the transmission
Is that correct ? Any help will be appreciate
Thanks Alex
Old Ray
Posted 2019-06-01 11:26 AM (#582798 - in reply to #582793)
Subject: RE: 1956 Plymouth
500
Sorry, I'm old and a bit slow. Are you wanting to change the transmission from a automatic to a standard with a column shift ?
Posted 2019-06-01 4:15 PM (#582802 - in reply to #582793)
20001000500100100252525
The factory parts manual shows the bell housing as a one-year-only for the '56 Plymouth V8.
Muffin1
Posted 2019-06-01 4:21 PM (#582804 - in reply to #582793)
Subject: Re: 1956 Plymouth
10010025
Yes from a automatic to a stick
Posted 2019-06-01 4:26 PM (#582805 - in reply to #582804)
500020002000500100100100100
Muffin1 - 2019-06-01 1:21 PM
And by "stick" do you mean "3 on the floor" or "3 on the tree (as in column)"??
(You are going to want to find a donor car for this conversion)
Muffin1
Posted 2019-06-01 10:45 PM (#582811 - in reply to #582793)
10010025
Yes would like to do 3 on the column . I need all the things to do that trans, bellhousing ,steering column, fly wheel , clutch and all
linkage . I have no luck finding anything, any help from any one would be apprecicate. A donor car would be nice
