1956 plymouth parts for sale (and a few for 1955) Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Forward Look Swap Meet -> For Sale - PARTS | Message format |
jerrybev |
Elite Veteran Posts: 689 Location: Winston Salem, N.C. | PARTS FOR SALE NOS : all $20 each: Temp gages, fuel gage, thermostat , oil pressure gage #13751A, headlight switch, VOLTAGE REGULATOR, NOS FUEL PUMP FOR V8 ENGINE $45, 1955-56, MASTER CYLINDER REPAIR KIT, $10THERMOSTAT 1955-56 PLY-DODGE NOS $10, WAGNER WHEEL CYLINDER KIT WK11345 NOS HAVE 2, $5 EACH, WAGNER WHEEL CYLINDER KIT WK11345 NOS HAVE 2, $5 EACH, BRAKE WHEEL CYLINDER REPAIR KIT FROM NAPA PART #201 & PART NO 212 HAVE 2 , $5 EACH, VOLTAGE REGULATOR $20, IGNITION RESISTOR V8# FROM A.L. WELLS CO. #795 $5, NAPA ROTOR HAVE 2 IN SAME BOX, # AL 125, HAVE 3, $2 EACH, GENERATOR BRUSHES NEW TUNGSTEN E46X, $5 HAVE 2, WAGNER WHEEL CYLINDER KIT WK11345 HAVE 2, $5 EACH, SBI 2 OIL SEALS $5, HUSKY PLUG WIRES $11 # V4080-8HES, $20, #1688647, THERMOSTAT NEW $10 (HAVE 2) , WATER PUMP REBUILT FOR V8 $20, IDLER ARM REPAIR KIT $20 USED: FREE 1956 POWERFLITE TRANSMISSION, OUTER GAS DOOR $10, TURQ COLOR, HOOD LATCH, GOOD WORKING CONDITION, $10, DISTRIBUTO HUBCAPS, $20 each, HOOD BIRD $35, CIGARETTE LIGHTER COMPLETE UNIT $25, RADIO, A.M. $65, BARREL CARB Carter WCFB 2202SA $70,2 318” POLY VALVE COVERS, NOT DENTED, $25 PR, 1955-56 SPEEDOMETER $25, 1956 SHIFT CABLES FOR TRANSMISSION POWERFLITE $12, POWERFLITE SHIFTER, WORKING CONDITION $75, DIPSTICK TUBE, POWERFLITE $10, CARB CHOKE $5, OIL BREATHER CAP $5, GENERATOR FAN DOUBLE PULLEY CAST IRON $30, CRANK SHAFT DAMPER PULLEY (2 GROOVES) FOR 8 CYL $12, WATER PUMP DOUBLE PULLEY 8 CYL $20, GENERATOR USED $25, LEFT REAR BUMPER BRACKET FOR 55-56 CAR, $15, SINGLE WATER PUMP PULLEY , BLACK, CLEAN, USED $5, GENERATOR NO DRIVE ON BACK OF IT $25, WATER PUMP BYPASS HOSE WITH CLAMP $10, CRANKSHAFT PULLEY, SINGLE, CLEAN, USED $20, SEAST TRACKS RIGHT FRONT AND LEFT FRONT $5 EACH, STEERING COLUMN FOR MANUAL, App. 4 FEET TALL $50, HEATER CORE NO LEAKS $30, INSIDE AND OUTSIDE HEATER BLOWER BOX WITH MOTOR $20 EACH, MANUAL STEERING LINKAGE $25, Jerry Whitfield, 2128 Leeds Lane, Winston Salem, N.C. 27103, phone 336-749-5922, or 336-765-8312 member #123109 | ||
jerrybev |
Elite Veteran Posts: 689 Location: Winston Salem, N.C. | hi here are a few pictures of some of the parts I have for sale. (IMG_0387 steering column xxxsmall.jpg) (IMG_0891 radio small.jpg) (IMG_0880 xxxsmall.jpg) (IMG_0393 gas door xxx small.jpg) (IMG_0882 xxx small.jpg) (IMG_0883 xxxsmall.jpg) Attachments ---------------- IMG_0387 steering column xxxsmall.jpg (54KB - 179 downloads) IMG_0891 radio small.jpg (42KB - 155 downloads) IMG_0880 xxxsmall.jpg (88KB - 152 downloads) IMG_0393 gas door xxx small.jpg (45KB - 160 downloads) IMG_0882 xxx small.jpg (98KB - 147 downloads) IMG_0883 xxxsmall.jpg (86KB - 157 downloads) | ||
Muffin1 |
Veteran Posts: 242 Location: Michigan | Hi Jerry, Please check your PM Alex | ||
brand209 |
Veteran Posts: 117 | hows the hood bird shape wise? would also be interested in any 4bbl and intakes for 277 | ||
jerrybev |
Elite Veteran Posts: 689 Location: Winston Salem, N.C. | hi I have a 4 barrel carb and intake for 1956 V8 . please email me at jerrybev1@yahoo.com because I am not receiving notifications of replies, even though I checked the box for it. thanks jerry whitfield Winston salem, N.Carolina | ||
jerrybev |
Elite Veteran Posts: 689 Location: Winston Salem, N.C. | hii I'll post pix of the engine parts. jerry (IMG_2147.JPG) (intake manifold.JPG) Attachments ---------------- IMG_2147.JPG (140KB - 123 downloads) intake manifold.JPG (89KB - 120 downloads) | ||
mstrug |
Expert 5K+ Posts: 6502 Location: Newark, Texas (Fort Worth) | I got the speaker grill! Thank Jerry! Marc. | ||
Steve1956 |
Regular Posts: 81 | Hi I have just seen your post. I have a car with a 1955 Plymouth dash. Would you have the lower half of the steering column clamp which I am missing? Thanks. Steve | ||
Expert 5K+ Posts: 9912 Location: Lower Mainland BC | Steve1956 - 2019-09-29 2:17 AM Hi I have just seen your post. I have a car with a 1955 Plymouth dash. Would you have the lower half of the steering column clamp which I am missing? Thanks. Steve Steve: Got your email. I don't have spare lower column clamp bracket like you are missing. If Jerry doesn't have one, I am quite sure that John at Big M will. Your situation (I think that you are looking for PN 1608 583): (SteveBs1956 DodgeRHDSteeringWheelShowingMissingBracket.jpg) (55-56PlymouthDashWithSteeringColumnCap.jpg) (55-56PlymouthDashWithSteeringColumnCapPN.jpg) Attachments ---------------- SteveBs1956 DodgeRHDSteeringWheelShowingMissingBracket.jpg (177KB - 109 downloads) 55-56PlymouthDashWithSteeringColumnCap.jpg (218KB - 116 downloads) 55-56PlymouthDashWithSteeringColumnCapPN.jpg (167KB - 118 downloads) | ||
RJTVX23 |
Member Posts: 11 | hi do you still have this ? CRANK SHAFT DAMPER PULLEY (2 GROOVES) FOR 8 CYL $12,WATER PUMP DOUBLE PULLEY 8 CYL $20 and these are for the poly engine? | ||
jerrybev |
Elite Veteran Posts: 689 Location: Winston Salem, N.C. | hi I am not being notified by this website when someone replies to my ad. That is why the delay in replying to you. Therefore please send me an email at jerrybev1@yahoo.com so we can communicate. I have the crank shaft damper pulley, and believe I have the water pump double pulley. It is dark now and I can't search. thank you jerry whitfield Winston salem, NC | ||
jerrybev |
Elite Veteran Posts: 689 Location: Winston Salem, N.C. | hi what I have is what you see in the picture of steering column in my ad. This site is not notifying me of replies to my ad. If you wish to communicate, please email me directly at jerrybev1@yahoo.com thank you jerry whitfield Winston salem, NC | ||
jerrybev |
Elite Veteran Posts: 689 Location: Winston Salem, N.C. | hi I am not receiving replies to my ad through the website here. If you still need any item, email me directly jerrybev1@yahoo.com thanks jerry whitfield Winston salem NC | ||
