56 Fury: fuel inlet leak Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Tony |
Elite Veteran Posts: 642 Location: Falcon, CO | Hi All, I'm assuming that there is a rubber ring or "O" ring between the small pipe and the tank. Who sells the seal? (100_9374rs.jpg) Attachments ---------------- 100_9374rs.jpg (66KB - 127 downloads) | ||
Expert 5K+ Posts: 9912 Location: Lower Mainland BC | I might be wrong, but I would have thought that a 56 Plymouth (even a Fury) would have fuel tank inlets and outlets similar to, if not identical to, those of a 56 Dodge. If that is the case, there are no O-rings on either the inlet or the outlet. The inlet is based on two different size hoses, a big one for the inlet proper and a smaller one for the overflow/vent line. Both are friction fit over beaded pipes with the added security of mechanical clamps. The outlet is a flared fitting/compression nut. No O-ring but sealing paste would be wise. See below: (56DodgeFuelTankInletAndOverflowHoses.jpg) (56DodgeFuelTankOutlet.jpg) Attachments ---------------- 56DodgeFuelTankInletAndOverflowHoses.jpg (201KB - 127 downloads) 56DodgeFuelTankOutlet.jpg (234KB - 137 downloads) | ||
Tony |
Elite Veteran Posts: 642 Location: Falcon, CO | The Fury has the inlet on the right side of the quarter down to the tank. I'll clean off the rubber hose, clamps, and lower pipe Thursday; and get a better look as to what's happening. | ||
Expert 5K+ Posts: 9912 Location: Lower Mainland BC | Tony - 2019-06-18 4:44 PM The Fury has the inlet on the right side of the quarter down to the tank. I'll clean off the rubber hose, clamps, and lower pipe Thursday; and get a better look as to what's happening. From an old fuel tank thread: DepsilonD - 2015-02-27 1:14 PM All 55-56 Dodge/Plymouth/Plodge Coupe and Sedan tanks are the same (17 gallon tank PT No. 1557 468, 20 gallon tank Pt. No. 1632 823). In addition, all 55-56 Dodge/Plymouth/Plodge Station Wagon Tanks are the same (17 gallon tank PT No. 1632 788). BUT, but the wagon tanks are different from the Sedan/Coupe tanks. I agree with those PNs (see below) Your tank should look something like this (from an old 2015 thread): or even better from this eBay advert: https://www.ebay.com/itm/1955-PLYMOUTH-BRAND-NEW-FUEL-GASOLINE-GAS-T... (eBay55PlymouthFuelTank_1.jpg) (eBay55PlymouthFuelTank_2.jpg) (55-56DodgeAndPlymouthFuelTankPNs.jpg) Attachments ---------------- eBay55PlymouthFuelTank_1.jpg (125KB - 144 downloads) eBay55PlymouthFuelTank_2.jpg (135KB - 120 downloads) 55-56DodgeAndPlymouthFuelTankPNs.jpg (219KB - 132 downloads) | ||
Tony |
Elite Veteran Posts: 642 Location: Falcon, CO | I pulled the original tank overflow rubber hose. It's the problem. (100_9422rs.jpg) Attachments ---------------- 100_9422rs.jpg (60KB - 136 downloads) | ||
Expert 5K+ Posts: 9912 Location: Lower Mainland BC | Tony - 2019-06-20 4:46 PM I pulled the original tank overflow rubber hose. It's the problem. Yup that would do it. I went with a standard fuel compatible bulk (on a roll) hose from a Friendly Local Auto Parts (FLAPs) store. Edited by 56D500boy 2019-06-20 11:15 PM | ||
