1959 Coronet Door Panel Removal
texas383
Posted 2019-06-24 11:01 AM (#583984)
Subject: 1959 Coronet Door Panel Removal
I'm needing to take the door panels off.
How are the inner door handles and window cranks removed? Do they pry off?
Also... I'm assuming that once the handles are off that the door panels have clips and pry off...?
Thanx for any help!
Posted 2019-06-24 11:10 AM (#583985 - in reply to #583984)
Subject: RE: 1959 Coronet Door Panel Removal
500020002000500100100100100
These threads should help you figure out about the clips:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=64288&...
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=69434&...
The proper door handle removal tool is the K-D 435 which grabs and squeezes the square clip that holds the handle to the square window/door handle posts:
BUT other means will work, including this:
REFERENCE: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=9023&p...
Edited by 56D500boy 2019-06-24 12:07 PM
texas383
Posted 2019-06-24 11:45 AM (#583990 - in reply to #583985)
AWESOME!!
Thank you VERY MUCH!
