1957 Dodge Parts Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Forward Look Swap Meet -> For Sale - PARTS | Message format |
legend57 |
Member Posts: 7 | We have some unused parts after our restoration/hot rod project on our 1957 Dodge Coronet. It will take a little while to get things organized for shipping, but wanted to see if there is any interest. I haven't worked out pricing yet. 325 Poly Motor - Ran (surprisingly well) before we pulled it out. Complete, 2-barrel carb to pan. Torqueflight Trans - Shifted fine in all gears. Driveshaft Rearend - From drum to drum. Brakes were rebuilt. Not sure of ratio yet. Front brake assemblies - L&R - Rebuilt. New master cylinder Radiator - Good core. Didn't leak when we last drove the car. Heater/Defrost cover and core - Not sure if the heater core leaks. 5 Royal Hubcaps Pushbutton assembly/mechanism Steering column Manual steering box Front Bench Seat There are a number of odds and ends from the engine bay. I'll have to itemize. 325 Hemi exhaust manifolds - L&R (I know I have at least one pair, maybe 2) 315/325 2bl intake manifold - cast iron 315/325 4bl intake manifold - cast iron 315/325 Water pump housing 315/325 water pumps - Cores. Should be rebuilt. A number of 315/325 pulleys - water pump and crankshaft Location is Northern CA. Thanks. | ||
1959 Belvedere Conv |
Elite Veteran Posts: 1107 Location: Arvada, Colorado (NW Denver Metro Area) | <div id="i4c-draggable-container" style="position: fixed; z-index: 1499; width: 0px; height: 0px;"> </div><p>Do you have a double groove water pump pulley for my 57 Dodge Convertible, I have added AC air to my car and am missing part. 325 powerplant John</p><div id="i4c-dialogs-container"> </div> Edited by 1959 Belvedere Conv 2019-10-17 5:10 PM | ||
Expert 5K+ Posts: 9911 Location: Lower Mainland BC | Rob: Check your private mail in your inbox here. | ||
Corsair |
Member Posts: 43 | I would be interested in the 315/325 4bl intake manifold and possibly the torqueflight trans. To go along with that 4bl manifold, would you happen to have the 4bl carb, air cleaner, automatic choke, and throttle linkage. | ||
Expert 5K+ Posts: 9911 Location: Lower Mainland BC | Corsair - 2019-10-19 7:07 PM I would be interested in the 315/325 4bl intake manifold and possibly the torqueflight trans. To go along with that 4bl manifold, would you happen to have the 4bl carb, air cleaner, automatic choke, and throttle linkage. I don't where he is. I called dibs on the Torqueflite via private mail 2 days ago but heard nothing back. Hopefully he is around. | ||
Odd |
Member Posts: 6 | I need the Front Bench Seat vith dip in the middel. 1957 Dodge Royal D500 Odd | ||
Expert 5K+ Posts: 5006 | i have a torqueflite and a seat but im in Ohio | ||
