1959 dodge cast iron torqueflite noise from trans Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | I have a 59 dodge cr with torqueflite , been sitting over 8 years , Got the engine fire up and purrrrs like a kitten. the trans shifts into first , second and drive but makes a clicking noise while pushing the button for Reverse. and it will not engage the tires to rotate. ALL ...... the shift buttons are all stiff and do not pop back out correctly when pressing the button. is there a way to lubricate this so the buttons will pop back out correctly ? I think the reverse button is not fully engaging . maybe there is a adjustment to this all so it engaging into each gear solidly. what do you all think ? Thanks ! Edited by dodge59 2019-10-24 7:49 PM | ||
Expert 5K+ Posts: 9909 Location: Lower Mainland BC | . If you don't have a Factory Service Manual (FSM), they are probably available as reprints on eBay. https://www.ebay.ca/itm/1958-1959-Dodge-Car-Shop-Manual/264446087944... In the short term, go to Mymopar.com and down load the closest Factory Service Manual pdf , e.g. 60 Dodge, 59 Plymouth, 58 Chrysler, etc. http://www.mymopar.com/index.php?pid=109 I have the 58 Chrysler pdf and on page 267 of 504, there is the start of an extensive Torqueflite section that should have the info that you are looking for. In the very short term, you could have a look at this thread for ideas and remove the shifter face plate and buttons and then the two nuts that hold the shifter box into the dash. Pull the shifter box out and spray the shifter slide plates with WD-40 and exercise them with the buttons. That should help (unless one of the return springs is broken) http://www.forwardlook.net/forums/forums/thread-view.asp?tid=70346&... Example shifter box showing shifter plates and buttons: Edited by 56D500boy 2019-10-24 11:10 PM | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | Thanks 56D500boy ! That was a Great help ! Yeah the buttons don't want to pop back out . I'll take a look in there lube it , and see if any springs are broken. I do have a service manual. | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | I take it there is a cable that runs down to the trans ... is there any adjustment to be made with the shift cable that runs down to the trans ? | ||
Expert 5K+ Posts: 9909 Location: Lower Mainland BC | dodge59 - 2019-10-24 5:49 PM I take it there is a cable that runs down to the trans ... is there any adjustment to be made with the shift cable that runs down to the trans ? Yes and Yes. (58ChryslerGearShiftControlOperation.jpg) (58ChryslerShifterInPage268of504inPdfServiceManual.jpg) (808-XXX_AA-5.jpg) (58ChryslerGearShiftControlOperationalSketch.jpg) (Cast-IronTFCableAdjustment.jpg) Attachments ---------------- 58ChryslerGearShiftControlOperation.jpg (147KB - 220 downloads) 58ChryslerShifterInPage268of504inPdfServiceManual.jpg (146KB - 215 downloads) 808-XXX_AA-5.jpg (71KB - 219 downloads) 58ChryslerGearShiftControlOperationalSketch.jpg (117KB - 227 downloads) Cast-IronTFCableAdjustment.jpg (242KB - 236 downloads) | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | Thanks again ! | ||
