1956 olymouth, dodge parts,( some fit more years) Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Forward Look Swap Meet -> For Sale - PARTS | Message format |
jerrybev |
Elite Veteran Posts: 689 Location: Winston Salem, N.C. | NOS GAGES $20 EACH: 1955 and 1956 TEMP GAGES, 1956, FUEL GAGE #1622135, THERMOSTAT 55-56 ply. & dodge, OIL PRESSURE GAGE 1955 #1622134, steering wheel center $50, front parking lamp lens and frame $25, taillight frame with red lens $25, chrome backup light frames above average condition $50, NAPA wheel cylinder kits #112 and 291, also Wagner, Borg Warner rotor button $5, generator brushes by Tungsten Co. $10, fuel gage tank assembly #1041679 $40, one bumper guard $10, ash tray $10, gas door $10, cigarette lighter $5, temp gage dash knob $5, exterior stainless trim body spears $20 each, rear view mirror $5, carb rebuild kit #10041 $20 1. 2 HUBCAPS, $20 each 3. 4 BARREL CARB Carter WCFB 2202SA $70 4. NEW FUEL PUMP FOR V8 ENGINE $45 1955-1956 5. MASTER CYLINDER REPAIR KIT, $10, NOS 6. SHIFT CABLES FOR TRANSMISSION POWERFLITE $12 7. POWERFLITE SHIFTER, WORKING CONDITION $75 8. DIPSTICK TUBE, POWERFLITE $10 9. CARB CHOKE $5 11. SBI 2 OIL SEALS NOS $5 12. GENERATOR FAN DOUBLE PULLEY CAST IRON $30 # stamped on unit is 98GWC2 13. CRANK SHAFT DAMPER PULLEY (2 GROOVES) FOR 8 CYL $12 14. WATER PUMP DOUBLE PULLEY 8 CYL $20 15. BRAKE WHEEL CYLINDER REPAIR KIT FROM NAPA PART #201 & PART NO 212 HAVE 2 , $5 EACH 16. WAGNER WHEEL CYLINDER KIT WK11345 NOS HAVE 2, $5 EACH 17. IGNITION RESISTOR V8# FROM A.L. WELLS CO. #795 $5 18. NAPA ROTOR HAVE 2 IN SAME BOX, # AL 125, HAVE 3, $2 EACH NEW 19. GENERATOR BRUSHES NEW TUNGSTEN E46X, $5 HAVE 2 20. ROTOR BUTTON,NEW BORG WARNER D-13 5HD $5 21. GENERATOR USED $25 22. LEFT REAR BUMPER BRACKET FOR 55-56 CAR, $15 23. SINGLE WATER PUMP PULLEY , BLACK, CLEAN, USED $5 24. GENERATOR NO DRIVE ON BACK OF IT $25 25. WATER PUMP BYPASS HOSE WITH CLAMP $10 26. CRANKSHAFT PULLEY, SINGLE, CLEAN, USED $20 27. SEAT TRACKS RIGHT FRONT AND LEFT FRONT $5 EACH 28. STEERING COLUMN FOR MANUAL 4 FEET TALL APPROXIMATELY $50 29. HEATER CORE NO LEAKS $30 30. INSIDE AND OUTSIDE HEATER BLOWER BOX WITH MOTOR $20 EACH 31. MANUAL STEERING LINKAGE $25 32. IDLER ARM REPAIR KIT $20 33. OUTER GAS DOOR $10 TURQ COLOR 34. HOOD LATCH, GOOD WORKING CONDITION, $10 35. DISTRIBUTOR $20 #1688647 36. THERMOSTAT NEW $10 (HAVE 1) 37. CIGARETTE LIGHTER COMPLETE UNIT $25 38. Ignition coil $10 thank you, Jerry Whitfield, Winston Salem, NC member #123109 NOTE: since I don't come to this site often and I don't understand PMs, BEST TO EMAIL ME DIRECTLY AT jerrybev1@yahoo.com Edited by jerrybev 2019-11-20 7:34 PM (1956 back up light chrome frame.JPG) (1956 under hood 2.JPG) (1956 ply pulleys 5.5 and 7 inches.JPG) (mopar carb rebuild kit xxxsmall.jpg) (56 ply hubcap.JPG) (1956 front end.JPG) (ash tray.JPG) (blower motor.JPG) (distributor.JPG) (geneerator 2.JPG) (IMG_2147.JPG) (IMG_2148.JPG) (IMG_2151.JPG) (steering wheel center.JPG) (wagon wings.JPG) Attachments ---------------- 1956 back up light chrome frame.JPG (104KB - 65 downloads) 1956 under hood 2.JPG (120KB - 64 downloads) 1956 ply pulleys 5.5 and 7 inches.JPG (207KB - 102 downloads) mopar carb rebuild kit xxxsmall.jpg (117KB - 77 downloads) 56 ply hubcap.JPG (92KB - 74 downloads) 1956 front end.JPG (188KB - 81 downloads) ash tray.JPG (140KB - 73 downloads) blower motor.JPG (160KB - 81 downloads) distributor.JPG (175KB - 82 downloads) geneerator 2.JPG (130KB - 84 downloads) IMG_2147.JPG (140KB - 67 downloads) IMG_2148.JPG (124KB - 93 downloads) IMG_2151.JPG (136KB - 88 downloads) steering wheel center.JPG (154KB - 80 downloads) wagon wings.JPG (191KB - 75 downloads) | ||
