'56 Headlight Bucket Info? Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
GaryS |
Expert Posts: 1207 Location: Ponder, TX | I tried finding an illustrated parts breakdown for a '56 Plymouth headlight bucket on the Internet, but no success. Does anyone have one to post, or know where it might be found on the net? Between my project and the parts car I can't salvage enough detail parts to make two good assemblies, but I'd like to see what all I need so I can search for good parts. Thanks! | ||
ABloch |
Expert Posts: 1477 Location: Pacific Northwest | http://www.mymopar.com/index.php?pid=107 Not as easy to navigate as the actual parts manual. Good luck! | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | I thought the headlight buckets were pretty universal for the Mopars of the era, so finding parts shouldn't be too tough. The "bucket" is aluminum with steel rivets and brackets, so there was usually some galvanic corrosion between the parts. I simply riveted the parts back together for my '56 Imperial. | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | Also, check your factory service manual, I recall a detailed view of all parts and adjustments. | ||
Expert 5K+ Posts: 9909 Location: Lower Mainland BC | jboymechanic - 2020-01-03 6:16 PM I thought the headlight buckets were pretty universal for the Mopars of the era, so finding parts shouldn't be too tough. The "bucket" is aluminum with steel rivets and brackets, so there was usually some galvanic corrosion between the parts. I simply riveted the parts back together for my '56 Imperial. There was a different PN for the 55-56 Plymouths and the 56 Dodges, etc. BUT 1626 512 crossed all lines in 1955 if you were looking for a good used headlight "SHELL", say from John at Big M. Edited by 56D500boy 2020-01-03 11:28 PM (55-58DodgePlymouthHeadLightShell_Diagram.jpg) (55-58DodgePlymouthHeadLightShell_PNs.jpg) Attachments ---------------- 55-58DodgePlymouthHeadLightShell_Diagram.jpg (238KB - 215 downloads) 55-58DodgePlymouthHeadLightShell_PNs.jpg (167KB - 210 downloads) | ||
GaryS |
Expert Posts: 1207 Location: Ponder, TX | Thanks guys! The factory service manual had almost nothing that helped establish which parts are needed. The things I'm missing are the springs, several screws and two nylon-thread nut plates. I suspected that they were similar or the same over several years, but one I got off my Fury parts car looked to be off a different manufacturer and nothing like a Chrysler product. At least now I can look for other models that will work. Thanks again for all the info. | ||
GaryS |
Expert Posts: 1207 Location: Ponder, TX | I really appreciate the links that identify the parts by the proper nomenclature. With that info I did a search and found a supplier(Auveco) that had dozens of different types of adjuster parts for dozens of different brands of cars. None were exactly the same as the '56 OEM parts, but I found nylon nuts and 1/4-28 adjuster screws that will do the job. I'll do with them what I've had to do with so many of the hard-to-find parts...make my own brackets to attach the modern, matching parts to the shell! By the way, they also have springs that match the one badly rusted spring I had. The spring anchor pin will also be a homemade part. | ||
