58 Desoto HT engine mounts.
582drht
Posted 2020-03-30 2:52 AM (#596221)
Subject: 58 Desoto HT engine mounts.
I am chasing the engine mounts for my Desoto and found some but it is the rubber only and not the casing how does that work?
Posted 2020-03-30 7:33 AM (#596225 - in reply to #596221)
Subject: Re: 58 Desoto HT engine mounts.
50001000500
You need the metal cylinders they go in.
Attachments 58engmt.jpeg (4KB - 202 downloads)
Attachments 58engmt2.jpeg (5KB - 192 downloads)
Posted 2020-03-30 7:32 PM (#596267 - in reply to #596225)
500020002000500100252525
Can they be pressed into the casing?
Posted 2020-03-31 5:28 PM (#596301 - in reply to #596221)
50001000500
Originally they just float in the 'cans', they tend to get stuck when the rubber fails from age and heat. The angle of them makes it possible to float a little bit and the engine not fly off. Install the new rubber cylinders you have when you get the engine metal mounts.
