cam base circle Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | has any one had issues with buying a bigger lift can and the base circle being different than oem . my 69 383 has been back together for some time now . breakin went well but after the breakin i have a very distinct valve tapping issue which sounds like all rockers . i'm about scared to take it back down and find something i don't want to see . it starts real , real easy even after setting a week or two , no missing , runs like hell til higher rpm then misfires , pops back through the carb but settles down quickly with less throttle and heat range is really cool . it has a howard cam , comp cam lifters and after market 8.75in push rods . ive had 383's in the past but none that put me back in the seat like this one but the tappin is drivin me nuts -----------------------------later | ||
Shep |
Expert Posts: 3398 Location: Chestertown, NY ( near Lake George) | Chuck, I think you need to get a dial indicator on some valves and check the lift vs the specs. Also you should pull the oil filter off, cut it open after draining it, lay out the inner element and look for metal. Check for broken valve springs. Are they oe springs or part of the kit, what is the gross lift. | ||
samstrader |
Extreme Veteran Posts: 445 Location: Beaumont TX | I had an issue with my valve rockers tapping on one side of my 1955 259...All the rockers were tapping but the two in the back were tapping louder. Right at first after rebuild, the tappets in the front were pretty quiet. Quiet for about 400 miles I think. After 500 or so miles, I pulled the valve cover and found there was zero oil going to the rockers. The cam bearing was installed wrong. | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Perhaps not related, but I renovated a Pontiac 350 cui with a mild Howard cam and lifters. All was good, breakin in and for a while. Then suddenly the Engine lost all oiling to the rockers and push-rods. 8 pushrods were practically chrushed at the end towards the rockers. When I ran the oil pump with a drilling machine - not a drop of oil came through the lifters. Removing one lifter gave a huge shot of oil, so nothing wrong with the Circuit. I finally opened and cleaned all the lifters - found some residue that looked like grinding dust inside the lifters - after cleaning thhe lifters and remounting them, the oil flow came back immediately. Engine still runs good after more than a year. Howard cams naturally never even responded to my questions aboth this issue……... | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Comp is notorious for sending the wrong lifters. So check and make sure that the oiling holes are at the proper height. Keep in mind that the proper height changed in 1966. Many cam sellers seem to be unaware of this change. If everything looks good, you may just need some adjustable push rods or rockers. | ||
wayfarer |
Elite Veteran Posts: 888 Location: Peoples Republic of Oregon | While things are still together, I'd suggest checking the lifter preload and see what you have. I like to see about 0.060" in the EarlyHemi's. | ||
58coupe |
Expert Posts: 1740 Location: Alaska | Are the replacement pushrods the same length as stock? If not, I agree with Wayfarer check the lifter preload. | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | thanks guys , i haven't left ya hangin just thinkin bout all the different things it could be and agreeing with them all . its just a matter of makin time to check everything one by one with preload and oiling being the first . my very next thing is removing my steering box for a rebuild . at 70 and broke down i just get don't goin like i used to . like today i put universal roof rack on my stepsons car for a kayak, like to ate my ass up in the heat and it aint even hot yet -------------------------------------------later | ||
