1956 Plymouth Body Codes
   Forward Look Technical Discussions -> Fender/VIN Tag and Broadcast Sheet DecodingMessage format
Posted 2020-07-30 9:10 PM (#601509)
Subject: 1956 Plymouth Body Codes
500020002000500100100100100
I started a 55 Plymouth Body code thread this AM and some of the responses to that one were really for 56 Plymouths. I said that I was going to also start a 56 Plymouth thread (in the future), BUT I guess I better get it going sooner than later, as in NOW.
This is what I hope to fill in:
(56PlymouthModelListing.jpg)
(56PlymouthCompleteLine_2.jpg)
Attachments 56PlymouthModelListing.jpg (73KB - 381 downloads)
Attachments 56PlymouthCompleteLine_2.jpg (204KB - 379 downloads)
Posted 2020-07-30 9:14 PM (#601510 - in reply to #601509)
Subject: RE: 1956 Plymouth Body Codes
This was one response in the 55 Plymouth body code thread (I think Igor meant 56 Plymouth) (I don't necessarily agree with him - yet):
frwl - 2020-07-30 11:13 AM
1955 Plymouth Body Codes
Plaza L6
513 = 2door Business Sedan
512 = 2door Sedan
510 = 4door Sedan
517 = Suburban 2door Station Wagon, 6P
518 = Suburban 4door Station Wagon, 6P
Plaza V8
612 = 2door Sedan
610 = 4door Sedan
617 = Suburban 2door Station Wagon, 6P
618 = Suburban 4door Station Wagon, 6P
Savoy L6
502 = 2door Sedan
500 = 4door Sedan
Savoy V8
602 = 2door Sedan
600 = 4door Sedan
Belvedere L6
702 = 2door Sedan
700 = 4door Sedan
703 = Hardtop Coupe
708 = Suburban 4door Station Wagon, 6P
Belvedere V8
802 = 2door Sedan
800 = 4door Sedan
803 = Hardtop Coupe
804 = Convertible Coupe
808 = Suburban 4door Station Wagon, 6P
Edited by 56D500boy 2020-07-30 9:15 PM
Posted 2020-07-30 9:18 PM (#601511 - in reply to #601510)
Another response to the 55 Plymouth Body Code thread (mine in this case), followed by Nathan's
56D500boy - 2020-07-30 12:27 PM
Thanks Igor and Robert. I am going to start a separate thread on 56 Plymouths.
I'm not liking the 55 two-digit codes. Many of them don't jive with the info that I got off the invoice copies.
Also Not sure about the three digit 56 Plymouth codes. I only have on 56 Plymouth body tag for a Belvedere and its BT (body code is 866). See below.
Powerflite - 2020-07-30 5:56 PM
I don't know what the 8 in front of the 2 digit code stands for. Maybe that is V8? But my V8 '56 Savoy 2dr sedan has body code 854. So the last two digits match up.
So now we can start on the 56 Codes in earnest.
Posted 2021-01-17 10:14 AM (#607807 - in reply to #601509)
Subject: Re: 1956 Plymouth Body Codes
100025
Ok, here's what i have - there are at least three types of body code markings
- first used on invoices:
10 Plymouth 6 Taxi
15 Plaza 6 4dr sedan
25 Savoy 6 4dr sedan
62 Fury
69 Belvedere 8 4dr sport sedan (HT)
- second used on LA plates:
P282 = 625 = Savoy 4dr sedan
P293 = 866 = Belvedere 2dr HT
- third used on Detroit and Evansville plates (if they are the same?)
201 = Savoy
301 = Belvedere 4dr sedan
302 = Belvedere 2dr sedan
404 = Fury
I think the invoice system corresponds to the LA system.
Edited by RDP 2021-01-17 10:19 AM
Posted 2021-01-17 2:11 PM (#607813 - in reply to #601509)
500020002000500100252525
Here are the pictures of the two '56 Plymouth body tags I have collected, along with one of my Fury's tag. 1st is a Belvedere 2dr sedan, 2nd a Belvedere 4dr sedan, 3rd is my '56 Fury. The two Belvedere's were made in Detroit, but my Fury was made at Evansville.
Edited by Powerflite 2021-01-17 2:27 PM
(56Belv 2dr Sedan Body Tag.jpg)
(56Belv 4dr Sedan Body No.jpg)
(56Fury Body Number.jpg)
Attachments 56Belv 2dr Sedan Body Tag.jpg (47KB - 287 downloads)
Attachments 56Belv 4dr Sedan Body No.jpg (82KB - 284 downloads)
Attachments 56Fury Body Number.jpg (224KB - 288 downloads)
Posted 2021-01-17 4:52 PM (#607820 - in reply to #601509)
1956 Belvedere Convertible from Detroit has a 309 body code.
(56Belv Vert.jpg)
Attachments 56Belv Vert.jpg (57KB - 293 downloads)
Posted 2021-01-17 6:20 PM (#607823 - in reply to #607820)
20001000500100100252525
Here's a snip from the build sheet for my '56 Plaza club sedan.
(Snip.PNG)
Attachments Snip.PNG (8KB - 294 downloads)
Posted 2021-01-17 8:30 PM (#607826 - in reply to #601509)
Thanks John. Which plant was it built in? I assume that since there isn't a letter after 102, that it was in Detroit - correct?
Edited by Powerflite 2021-01-17 8:32 PM
Posted 2021-01-18 11:13 AM (#607841 - in reply to #601509)
100025
The numbers used on the invoices is the same like numbers used on the IBM cards and the Chrysler Historical letters.
I suppose that explains the LA tagging. If the first number is an engine (LA tag), it might look like this:
- invoices, IBM:
10 = Plymouth 6 Taxi
14 = Plaza 6 2 dr sedan
15 = Plaza 6 4dr sedan
25 = Savoy 6 4dr sedan
62 = Fury
66 = Belvedere 8 2dr HT (???)
69 = Belvedere 8 4dr HT
- LA plates:
Pxxx = 610 = Plaza 6 TAXI (???)
Pxxx = 614 = Plaza 6 2dr Sedan (???)
Pxxx = 615 = Plaza 6 4 dr sedan (???)
P282 = 625 = Savoy 6 4dr sedan
Pxxx = 862 = Fury (???)
P293 = 866 = Belvedere 8 2dr HT
Pxxx = 869 = Belvedere 8 4dr HT (???)
- Detroit and Evansville plates (if they are the same?)
101 = Plaza 4dr sedan (???)
102 = Plaza 2dr sedan
201 = Savoy (4dr sedan?)
202 = Savoy 2dr sedan (???)
203 = Savoy 2dr HT (???)
303 = Belvedere 4dr HT (???)
304 = Belvedre 2dr HT (???)
305 = Belvedere Conv. (???)
404 = Fury
Edited by RDP 2021-01-18 11:16 AM
Posted 2021-01-18 12:30 PM (#607845 - in reply to #601509)
Robert, your list is wrong. I just showed you that a Belvedere convertible has a code 309. And a Savoy 2dr hardtop should be 204, right?
Posted 2021-01-18 12:49 PM (#607846 - in reply to #607845)
100025
Ok, you're right
1xx = Plaza, 2xx = Savoy, 3xx = Belvedere, 4xx = Fury
xx1 = 4dr sedan, xx2 = 2dr sedan, xx3 = 4dr HT, xx4 = 2dr HT, xx9 = Conv.
201 = Savoy 4dr sedan
204 = Savoy 2dr HT
309 = Belvedere Conv.
404 = Fury 2dr HT
Posted 2021-01-19 2:40 PM (#607892 - in reply to #601509)
100025
(56Plym.JPG)
Attachments 56Plym.JPG (79KB - 301 downloads)
Posted 2021-01-22 5:33 AM (#608014 - in reply to #601509)
1000500100100100252525
According to the «MOPAR PASSENGER CAR PARTS LIST» book, all 1956 Furys were built in Detroit Plant;
However the IBM-card one of them says overwise…
This one built in Evansville…
That’s oddly…
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=75246&...
(2.jpg)
Attachments 1.jpg (129KB - 285 downloads)
Attachments 2.jpg (35KB - 282 downloads)
Posted 2021-01-22 10:48 AM (#608021 - in reply to #608014)
I do see the 62 body code = Fury and the Evansville VIN. I also see "RAIL" and the Route = 5? (upper right corner)(from Column 10)
Edited by 56D500boy 2021-01-22 10:52 AM
(56FuryIBMCard_Route3Rail.jpg)
Attachments 56FuryIBMCard_Route3Rail.jpg (108KB - 285 downloads)
Posted 2021-01-22 11:02 AM (#608023 - in reply to #601509)
All '56 Furys were built at Evansville, for sure. Every body tag on them are always 404-E XXXX. That parts list statement is wrong.
Edited by Powerflite 2021-01-22 12:20 PM
Posted 2021-01-22 11:59 AM (#608029 - in reply to #601509)
100025
corrected
blue = guess
Edited by RDP 2021-01-22 12:02 PM
(56plym.JPG)
Attachments 56plym.JPG (80KB - 279 downloads)
Posted 2021-01-22 3:02 PM (#608043 - in reply to #601509)
I guess «Route 5 = Rail» column next to «NNN» column in the middle of IBM-card…
Posted 2021-01-22 3:04 PM (#608044 - in reply to #601509)
Upper Middle...
Posted 2021-03-24 2:32 PM (#610314 - in reply to #601509)
100025
A little better table.
The blue codes are just a guess. They need confirmation.
(p56-1.JPG)
(p56-2.JPG)
Attachments p56-1.JPG (85KB - 261 downloads)
Attachments p56-2.JPG (86KB - 261 downloads)
Posted 2021-03-24 2:37 PM (#610315 - in reply to #601509)
100025
Where would I find the data plate on 56 Plymouth?
(p56-3.JPG)
(p56-4.JPG)
Attachments p56-3.JPG (51KB - 271 downloads)
Attachments p56-4.JPG (63KB - 254 downloads)
Posted 2023-07-13 6:07 PM (#630754 - in reply to #610315)
Is this body trim list diagram going to help or hinder our attempts at nailing down the 1956 Plymouth Body Codes:
Edited by 56D500boy 2023-07-13 6:09 PM
(55-56PlymouthModelsFromDec1991_CA_mag.jpg)
Attachments 55-56PlymouthModelsFromDec1991_CA_mag.jpg (148KB - 60 downloads)
Posted 2023-07-15 2:00 PM (#630785 - in reply to #630754)
56D500boy - 2023-07-13 6:07 PM
This will go more for understanding exterior trim packages
(56.jpg)
Attachments 56.jpg (41KB - 60 downloads)
Posted 2024-04-21 6:24 AM (#634803 - in reply to #601509)
100025
Here is the body tag of a 1956 Belvedere 4dHT. This is number 305, not 303 as I previously thought.
So, below is the corrected table.
black = confirmed
blue = guesses
(56 Belv 4dHT.jpg)
(56p-2.jpg)
Attachments 56 Belv 4dHT.jpg (44KB - 9 downloads)
Attachments 56p-2.jpg (100KB - 9 downloads)
